Question about LG WM-2277HW Front Load Washer
Dispenser wont open
Soap
  • eric bosman
    eric bosman May 11, 2010
    ? can you be more clear?
  • 489 Answers
The dispenser has jammed against the drawer and will need to be checked out by a qualified LG technician.  They will have to remove the top of the machine to gain access to the dispenser.  The dispenser has a top section that can be unsnapped to gain access to the drawer for removal.
Posted on Jul 23, 2008
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
My dish washer wont finish cycle and wont open soap door
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 22, 2011 | Dishwashers
My soap dispenser wont open during the cycle
heatman101
Jan 04, 2011 | Maytag Dishwashers
My older model whirlpool dishwasher soap dispenser cap wont open...
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser wont open to release detergent?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
Soap door wont open
I have replaced a dish washer soap dispenser once. Not hard to do. Need the make and model number. This dispenser is activated mechanically so there may be a broken latch or spring in the dispenser. Check the dispensers operation manually and see if it appears to be operating normally.
Jan 16, 2010 | Frigidaire FDBB1940D Dishwasher
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Soap dispenser door does not open during wash cycle
Here's a link to an article on why the soap dispenser won't open and tests to find the issue so you can resolve it...
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=cup-wont-open
Oct 18, 2009 | Bosch 24 in. SHX33A05 Stainless Steel...
Detergent dispenser wont open
there is a problem with the soap dispenser not getting signal to open 9 out of ten times it is the dispenser its self and needs to be replaced the other problem is the main control board
Sep 16, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
LG WM-2277HW Front Load Washer Logo
195 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
