Question about GE Refrigerators
French door style frig. model #PR22sbsbss Door does not close all the way by itself. it will sit just open enough to let cooled air out and hot air in but not activate the "open" beeper. i've had a tech out to the house and he said it was fine. In addition, the temperature panel works on sometimes.
  • 2,427 Answers
The magnet seal arount the door needs to be replace, ypu can purchsase this and simply remove the old and and glue on the new one.
another quick fix method is to use a hax and staple type lock and screw the stape on the frodge and the hax on the door sor sfter you puch in the door simply staple it shut.
Posted on Jul 19, 2008
Fridge doors do not close completely
1st ckeck that nothing is sticking out just far enough to pop the door open.if not that, than the gaskets can were out on frig doors , you can order it on line from all appliances, get the model # from inside the frig , be patient installing it , its tricky, but it can be done by Harry homeowner. good luck.
May 04, 2012 | Maytag MSD2756GES Side by Side...
French doors - when you close one side the other pops open especially when the door is closed hard
This is normal operation,the new units are very efficient and air tight so when you close one door especially hard you are forcing air into the inside that has to escape somewhere therefor it forces the door that is stationary open just enough for the air to escape,as long as the door closes back afterward you have no problem if the door opens and swings out,then you would have a leveling problem the fridge would be leaning too far to the front.
Sep 27, 2009 | Maytag MFD2560HES Bottom Freezer French...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Refrigerator door not closing all the way
the pressure inside the box is pussing the other door open and what you need to do is tilt your refrig back until the door will close by itself and that will be as far as you need to go back with it ,,,, it's normal for it to happen and a frig should always have a little tilt / larryyb
Nov 28, 2008 | Refrigerators
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
