Question about Soyo Computers & Internet
Monitor went black no picture no cable problem
    Scholar:
  • 174 Answers
Remove the vga cable and see any display is coming up in your laptop like no connection or no signal
If not assume your monitor is gone so far from you, catch a new one and let it go
Thanks Hothawk
Posted on Jul 19, 2008
My monitor Chimei CMV 946A gets 2 sec. picture but then went black. power still on
Excuse me but your descripton is not clear enough. Do you get ALWAYS 2 seconds of picture and then your monitor goes black or it went black after 2 seconds and you never more got a screen
In any case, ask help from a friend, letting you to connect your monitor to another computer. Would pinpoint problem and discard eventual video card issue.
Aug 22, 2015 | Computers & Internet
Acer gd235hz 23.6 lcd monitor is blank on the right side only the left side of the screen shows pictures
It sounds like the monitor is broken. You should probably just buy a new one. If you haven't already, try checking the cable connections to the pc. Outside of that, there's not much you can do. Hopefully you still have a warranty on it and cant have it fixed.
Oct 18, 2017 | Acer Gd235hz 23.6" Lcd Monitor - Black
MY MONITOR WENT BLACK, ABOUT SIX YRS OLD. STILL WORKS JUST CANNOT SEE ANYTHING. CAN THIS BE FIXED?
Have you check all connection to see if they are right, check if no cable was unplug, if you have and yet no picture display, It could be that the picture board on your monitor has started malfunctioning, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 06, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
My laptop screen went black. Laptop won't turn
It powers on but there's no visible picture. Have you tried plugging in a VGA cable to an external monitor for picture? If you see a picture that means the lamp inside the screen went out on the LCD, which is cheaper than replacing the entire screen about 200 dollars cheaper.
Apr 08, 2010 | HP Pavilion dv7-1132nr Notebook PC
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Screen went black while i was on it and i have not gotten a picture since
try this first if you disconnect the cable and you get warning on the screen that the cable is disconnected,chances are the monitor is still good,next you might want to check if its set to digital or analog,
Good luck
Aug 26, 2009 | Samsung Syncmaster 192N 19" LCD Monitor
No picture on monitor 997M
One reason that this is happening could be that it is on Power saving mode. This happens when the LCD monitor detecs an incorrect timing then thats the time that the LCD goes blank and the power botton starts to blink.
what you need to do is to turn the computer off. Unplug cables attach to the LCD make sure it is also off, once done press the power botton for a couple of 30secs to a minute and then release. After doing so re-connect all the cables and make sure that both ends is tight and secure once everything is ok turn the computer on same with the monitor to check if it solves the problem.
Jan 08, 2009 | Microtech Computers & Internet
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Computers & Internet Logo
119 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
