Cannot change dispaly setting for monitor after reformatting...only 16 bit available & only 640x480
  • dev268 Jul 20, 2008
    THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Scholar:
  • 174 Answers
After your reformatting you removed the VGA driver and your driver is not a built in driver along with windows
Solution - open your pc note down the vga card chip details over the chip or from the manufacturer label or are you able to watch closely while your computer power up - It will display about the VGA card properties such as manufacturer it capacity etc....
Go to www.google.com search for it driver from the net and download it and install it in your pc - solve all your problems
May be now your sound also not working same thing you do or find a driver cd you got along with your computer - run it
Thanks Hothawk
Posted on Jul 19, 2008
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Need code for interex adapter please help Tomas t.matos2@hotmail.com
MONITOR RESOLUTION SETTING
12" RGB 512x348 13467
13" RGB 640x480 66Hz 1467
PORTRAIT 640x870 23467
VGA/SVGA 640x480/800x600 60 Hz 2367
15" TILT N/A 2467
16" COLOR 832x624 1367
19" COLOR 1024x768 1267
21" COLOR 1152x870 123467
2 PG MONO 1152x870 3467
NTSC N/A 12467
NTSC/PAL N/A 12367
HI-RES 12-14" up to 640x480 1467
MULTI SCAN 14" up to 832x624 146789
MULTI SCAN 16" up to 1024x768 14679
MULTI SCAN 21" up to 1280x1024 14678
Jan 07, 2011 | Interex Serial adapter
Monitor troubling by changing the menu settings by itself
If the monitor only displays 640x480 & 16 colors, it sounds like the display adapter is using standard windows svga drivers. (Unless you have a VERY old monitor that can't display more than that.) Have you tried reinstalling the drivers that came with your video card ?
Click on "start", then "Run".
type in "msconfig" (no quotation marks)
It should open the system configuration-thingy.
If it is set to anything other than "normal startup" (ie diagnostic startup), change it back to "normal startup". Click "apply", "ok", and then restart your computer. You will hopefully be able to change your settings again.
If everything fails change your video card
Thanks.If this solution works for you then please rate me.
Jul 07, 2010 | HP Computers & Internet
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Monitor
Install the Drivers. The CD you received is just the basic Windows Install. You can download the drivers at support.dell.com Install order: Desktop System Software (If available) Chipset utility Video Driver Audio Driver Network Driver then install applications like Roxio/Sonic and DVD player
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
Cannot set resolution higher than 640x480
what monitor,?
did you load the most current Nvidia driver from Nvidia.?
what OS?
we can not guess any of that.
May 19, 2017 | HP NVIDIA GeForce4 MX420 (64 MB) Graphic...
My screen resolution wont go above 640x480 pixels,16 colors
that probably the highest ur screen can go unless u update ur video card u can purchase some really good video cards at Best Buy or Wal mart Looking to help u Shaun
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
