Question about Sony PlayStation Portable (PSP) Console
PSP Not Working
My PSP Fell in Water. It turns on but the volume , x button , home button won't work. When i turn off the PSP the green light doesn't turn off.
Hey, try taking the faceplate and screen off. Get a blowdryer and dry. This sometimes fixes the problem.
Posted on Jul 20, 2008
  • maherdavid26 Mar 28, 2011
    you need a new battrey if the screen is blace or send your psp to me and ill get them fixed it will cost $2 just send it to 39 onslow st ohingatti no city post code 4785 send it to me and ill get it fixed really
Need help my psp is not working when I turn on I can only see the green light no sounds no display just green light and after a few seconds later it turns off the last thing I did I update with something...
First you have to take out the battery and use charger to turned on and when it turn on just put on the battery or take out the battery and wait for minutes then put it on and tur on,if that doesn't work when you turn on just hold R and start or repair it
Feb 06, 2013 | Sony PlayStation Portable (PSP) Slim...
Dropped phone and now doesn't work
Try any of the below combination.
  1. Hold Volume Up + Volume Down + Power.
  2. Hold Volume Up + Home + Power.
  3. Hold Home + Power.
  4. Hold Volume Up + Camera
Dec 12, 2017 | Samsung Cell Phones
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
Wet psp volume and home does not work, can not recharge battery
Your PSP is bricked, and unfortunately this cannot be fixed because its a hardware brick. The PSP needs to be replaced.
Sorry
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
I have a sony 2001 PSP, and I've had it for less than a month and just recently I tried to use it, when i attempt to turn it on I press the power button and the green light (which shows that the PSP is on)...
For how long have you NOT been using your PSP? and did anything happen before you even tried using it AGAIN? Do you have others in your area who has a PSP? if nothing happened to your psp before you tried using it again e.g.accidentally fell or something like that, then just try to use a different WORKING psp battery...if it didn't work, then prolly your PSP went brick and the only solution for that is a pandora kit...
Jul 22, 2008 | Sony PlayStation Portable (PSP) Console
Power light on but still not working
Check ur firmware, (if ur PSP installed custom firmware e.g. OE, M33.) goto "recovery mode", press and hold R(right button) while turn on ur psp. if u can go, simple use pandora battery for downgrade/upgarde ur psp. see at, http://e-arena.blogspot.com
Oct 22, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
