Question about Compaq Presario 700 470024-192 Notebook
Compaq Presario v2000 w/ dead USB ports
The usb ports on my v2000 no longer work. When I plug in any USB device it is not recognized. Everything else on the machine is working fine (wifi, ethernet, DVD - CDRW, etc.).
I have tried reinstalling the drivers, but that has not worked. Could it be a hardware problem?
Help!!!!!!!!!!!!!!!!!!!!
Ma usb is reli makin me go crazy,it recognizes onli 1 of my fons @ de port on de left side,put plugged in on the otha side,the phone senses the usb connection but de laptop dosn't.Apart from de fon anythin i plugged in so far doen't work even a mouse,de optical lite under de mouse doesn't even lite up.its de same on de otha port which works wit de fon n onli de fon.pls i need help,u think its hadware or sumthin diff?????????????am open 2 any opinion,thankz,I use a compaq Presario C727US notebook Pc
  • 1 more comment
  • clausn1 Jul 20, 2008
    de 1 dat works onli works wit ma old fon sonyericsson fon,but plug in anythin else n nuttin happens.but plug in de old fon n it works alrite
  • Kannan Sep 06, 2008
    how can i install drivers i download with compaq site with system name but it failed plz help me
    Scholar:
  • 174 Answers
If you short the usb connection controlled can burn out so it will not detect any device but your are tated that USB device is not recoginzed - if this message came that means your usb is ok the device you are attaching is not working
Posted on Jul 19, 2008
  • Matson Kurian
    Matson Kurian Jul 20, 2008
    All ina hurry I answer your problem Lets us do a test over your computer please follow the instructions.
    Warning if your USB ports are short the device you might connect to the port will burn it chip and will damage also note that you may find many or more than two ports but the power circut is same, so any port will get short the entire pc hangs or go blind. this reason also end up you entire system faulty.
    Usb devices are getting power from the systems old versions usb devices required double power so you may find olden cables having two end ports such devices required more power than the normal usb supply I hope you are ready for the action
    Connect any working USB device and see any popup messsage is coming up like Unrecoginzed device or not compatiable device that means 90% hope.
    Right click my computer icon and click properties and then do to hardware -> device manager - under USB - Universal Serial Bus controllers uninstall everything and restart your PC.
    If nothing is happened while you connect the usb device change the posrt and check each port and if every port are same I am sorry your port controller is damaged and your usb ports will not work
    thanks Hothawk
    Genius:
  • 2,028 Answers
Since you've done the driver thing, the only thing left is the ports themselves. USB ports can break or malfunction very easily. I'm going to say that you will need to replace the ports.
  • 2,794 Answers
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
The usb ports on my v2000 no longer work. When I plug in any usb device it is not recognized.
Try reinstalling the usb drivers for your computer. You can also check to see if its a hardware issue by pluging a usb powered device like a cooling pad in the usb port. If it gets power, chances are its a software issue. If no, then its a hardware issue.
May 21, 2010 | HP Compaq Presario V2000 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Ports-Connection
Hi
In your device list, don't you see USB ports isntalled?
If not, you need to install them first.
And if you can't have them installed or recognized by windows, you should enable them from your BIOS setup.
In your Bios Setup, search for "On Board Devices" and go to "On Board USB" then change it to Enable if it's Disable.
Save changes, restart you computer, then wait for windows to log on and wait for the USB ports to be recognized by Windows. Finally try the Printer.
If the problem presets, you may need to buy a USB Card which is not expensive.
I would be more happy to help if any drivers needed.
Oct 30, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 notebook freezes
Did you reset your BIOS? sounds like your usb is not configured properly
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Usb ports don't work
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario Desktop USB Problem
Go back in to th device manager
Look for the yellow and re-install them
Let me know
Jaywizz
Nov 19, 2007 | HP Compaq Presario V2000 Notebook
I have the same problem with my Compaq Presario V2000. Lost both USB ports and HP tells me that the motherboard has to be replaced at $300 +..I searched and found a PCMCIA card with two USB ports for $10. No problems with the USB ports on this card..great and cheap solution.
My belief is that the compaq usb ports do not have power limiting circuitry therefore allowing you to overload the output power on the ports. My ports failed after I downloaded into a burglar alarm system I was programming.
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
USB Ports crashing system
If you have done a system restore you have probably restored your problem with limewire also, although what it is that's related I don't know, it's more than likely a dial up or connection problem that is causing limewire to freeze yur system. Check your usb ports in device manager see if there is an exclamation mark or a cross, then refer to this solution for further checks. http://www.fixya.com/support/t125452-another_device_installation_underway
Nov 29, 2006 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
750 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
