Question about Karcher 2500 PSI Pressure Washer
Engine cutting out
I squeeze the trigger. I have pressure for 2-4 seconds and then the engine dies.
  • jkhobbs Jul 20, 2008
    The motor runs fine until I squeeze the trigger and then it cuts out, backfires, and dies.
    Master:
  • 726 Answers
Check there is not to much fuel flowing and flooding it and also the carby might need a tune
Posted on Jul 20, 2008
  • 19,396 Answers
Check that the fuel is flowing, there should be an fuel filter, check it out.
  • Ginko
    Ginko Jul 20, 2008
    Eventually replace the fuel filter , check that the carburetor filter is not dirty. Also check , and clean or replace spark plug.
    If the above did not work you will need to check the fuel pump and if it is not the fuel, to take apart and clean the carburetor.
  • Ginko
    Ginko Jul 20, 2008
    When you squeeze trigger you open the throttle and pump more fuel into carburetor. It is probably just a carburetion problem, you have it fixed by setting the two screws (max and min ) at the base of carburetor, this job should be done by an expert or a mechanic.
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
I have a craftsman 675 pressure washer. It runs fine. But when I turn on the water, it dies. What is wrong with it?
either the engine is worn and has no power or the pump is overloading the engine........
squeeze the trigger before you turn on the water.....
try no high pressure hose to make sure the water exits the pump ok
Sep 01, 2013 | Craftsman Garden
HAS NO POWER AND DIES OUT WHEN GIVING MORE THROTTLE OR TRYING TO CUT
I have the same problem. Can't find my manual to look up trouble-shooting guide. Did following, but same symtom after:
1.) Clean air and fuel filter
2.) Replace gas lines with "tygon" tubing; check for kinks in gas lines.
Observations:
1.) Runs good for about 20 seconds then dies slow death. Starts and idles good.
2.) Air bubbles in primer squeeze bulb.
3.) Gas tank is pressurized.
My next trial and error mission:
1.) Fresh gas and oil mix.
2.) Remove gas and oil filters for bench test
3.) Replace primer tube (it is smaller than gas tube) so I cut ends and re-used old.
If you have pin-pointed the problem let me know. It sure seems like gas starvation.
Jan 13, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
Engine starts easily and then stalls, is hard to restart
If the engine dies shortly after start. Squeeze the spray wand trigger to release pressure on the unit. When restarting let the engine run for a few min(2-3 no more) to warm up, the unloader valve on the pump should keep pressure to a minimum. If the engine stalls or will not run you need to check your carburetor and clean it. BECAREFUL as FUEL is FLAMMABLE and there are small parts in the carb float bowl that like to get lost. A rebuild kit for most carbs is less than $8USD and a can of spray carb cleaner about$2-3. Install a fuel cut off valve($6) to keep the carb from gumming up again. Shut off the fuel when not in use or for periods of prolonged storage. Take a picture of the carb on the engine(my memory is bad) and during disassembly to assure you get it back together properly. The idle screw should be turned in(to the right)till it seats lightly then backed out 1&1/2 to 2&1/2 turns to start with. After starting the engine adjust for good idle and running buy turning in or out to attain the best idle. If this is helpful, Please leave Feedback. Thanks, SnugglePants
Oct 21, 2009 | Coleman Garden
Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Engine starts cuts out when trigger squeezed
plugged fuel filter or bad gas
Jun 27, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
129 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
