Question about Cameras
The usb cable will not insert in my Z1275 connection
  • 797 Answers
You may not have the correct cable.
Be sure to check the connection to the camera.
If you have the wrong cable, then you will have to find one at some store, or a place such as Ebay or Yahoo, or a search on the Internet.
Posted on Jul 19, 2008
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from Kodak EASYSHARE Z1275 12.0 MP Digital Camera providing that I am using rechargeable batteries inside the...
No. The Z1275 is not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera using a separate battery charger.
Aug 19, 2013 | Kodak EasyShare Z1275 Digital Camera
Can I connect this unit to my computer using a standard cable instead of USB?
What kind of standard cable are you referring to? Is it a cable that you would insert to connect to cable tv? Unless your PC and printer has a space where you can insert a cable you will need a USB.
Aug 13, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do you get music to save on a new 4gb memory card on a nokia E5 instead of saving in phone memory
Transfer music from a computer
You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download
the PC software from, and follow the instructions.
• To view your device on a computer as a mass memory device where you can
transfer any data files, make the connection with a compatible USB data cable
or Bluetooth connectivity. If you are using a USB data cable, select Mass
storage as the USB connection mode. A compatible memory card must be
inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB
data cable, and select PC Suite as the USB connection mode. A compatible
memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel >
Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Nokia E5 Cell Phone
I up lode the pc sute for nokia 2690 but the connectivity is not there its shows that usb modem is not connected
uninstall the pc suite first. > go to device manager by typing "devmgmt.msc" in "run" > check if there the nokia hardware is listed there or not. > if it is there uninstall it. > restart the system and install the software. > when it prompts to insert the usb cable insert it. > it will automatically detect the cable and will install the firmware from the mobile. > after installing it will work fine.
mail me
Jan 14, 2011 | Computers & Internet
My computer does not regonise the usb cable it
Try another USB cable to see if that works. Also try pluging the cable into another port on your computer in case the port you use for that application is worn causing a bad connection. start with basics first.
Aug 10, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Kodak EsasyShare Z712 IS. I
If you have a PictBridge-compatible printer, you can simply connect the camera to the printer using the USB cable.
Alternatively, you can copy pictures from the internal memory to a memory card. Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Continue on to select your desired options.
Mar 24, 2010 | Kodak EasyShare Z1275 Digital Camera
Cable connection wont go in all the way
Are you talking about the automobile charging cable or the USB cable to connect to your home computer? In either case, the mini USB plug should make contact in the back of the GPS without having to be inserted more than about 1/4". Note that one side of the socket is wider than the other, as is also the case with the plug.
At the other end (of the computer USB cable), the full sized USB plug should insert about 1/2". One thing that I've noticed on my Garmin cable is that the "GARMIN" is on the back side of the end that plugs into the computer. Most USB plugs have the USB icon on the front, but that's blank on the Garmin cable. If you attempt to insert the plug backwards, it won't go in all the way.
Good luck.
Mar 10, 2010 | Garmin GPS
I cannot download pictures from camera to my computer. My computer does not recognize the camera.
Hello, I not sure if this well help, but this is the information that came with my Z1275.
Minimum System Req:
Windows OS XP or later, Internet Explorer 6.0 or higher
600 MHz processor or higher
Macintosh OS X 10.3 or higher
Minimum Hardware:
128 MB ram
200 MB available disk space
CD-Rom drive
USB port
I have vista on my computer and I looked on kodak help site and I did not find any updated or conversion software for the Z1275 camera.
I use a SD card and then put the SD card in my computer to transfer pictures.
Aug 03, 2009 | Kodak EasyShare Z1275 Digital Camera
Connecting to computer
U can directly insert the cd to ur system...
For usb cable see the catalog...
Thank you
Dec 21, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony ericsson k800i connection to laptop to upload phots
First uninstall all the drivers and of the phone and the software, then remove the cable usb of the phone and restart the computer, insert the software CD and install the software's while installing at one point it will ask to insert the usb cable of the phone at that time insert only the cable without the phone, after installing restart the computer again, now you can connect the phone to the USB cable, when you connect the cable, the phone will automatically ditect and wait for sometime cos the computer will install some drivers to the phone. when this is finished try using
May 09, 2008 | Sony Ericsson K800i Cellular Phone
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
