Question about Carrier 36KCARMS Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Carrier Air Condition, cool air then runs luke warm air. Cleaned the inside and outside unit. Outside fan is running fine, however, the outside unit is hot to the touch. Why is the air condition only give us cool air for 15 minutes or so, then turn luke warm, and why is the outside unit becoming hot to the touch?
  • 18 Answers
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
Ptac unit wont cool
Check unit's ID#'s and add any hyphens, etc or separate letters, numbers, to be exactly what's on unit.
Inside sources might help. Popular Questions Answers Tips Manuals for Carrier 52CE215 Cool Electric...
Questions Answers for Carrier heating element
Feb 11, 2015 | Carrier 52CE215 Cool Electric Heat Air...
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
My air conditioner froze up. We turned it off over night and cleaned the evaporator and condenser now it doesn't cool at all.
is the outside unit running? may have got something wet have someone turn it to cool while your at outside unit see if it's starting up. one line should be warm the other cool.
Jun 18, 2014 | Goodman Heating & Cooling
Our carrier air conditioner failed to cool down the house last night. changed the filter and still struggling to cool house down.
is it cooling some at night but none during the day basically ? Outside unit clean also ? Good airflow ? if yes on all of these feel the copper pipes that go inside the house from the outside and once a/c has been on for a few minutes the large line should be very cool or cold to where it would condensate.. Sometimes it may take up to 15 minutes..
Aug 20, 2010 | Carrier 38CKC024 Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Duo Therm RV air conditioner inadequate cooling
The rule of thumb is 20F difference (lower) than ambient temperature. Most manufacturers will tell you 20 F degress is about normal. In your case it does sound a little warm, but I need to ask, sorry. Was it working o.k. before in same basic temperatures? Have you cleaned coils & fins good on Evaporator & condenser recently? Have you removed filter inside & cleaned it as well, and looked to see if coils are frosting up by chance? Is this a ducted or non ducted system? I'm guessing on a 5th wheel, it is ducted, so make sure you have good discharge on all of those as well. Any blockage or restriction on the discharge side will also cause the problem. Keep me posted on what you find.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Heat pump not cooling after 1 hour
Yes it is true . Sound like you are low on freon the unit is shutting off on the low pressure switch or high pressure switch is the outside unit clean ?you may need service. Tom
Jun 17, 2009 | Carrier CARH09K Air Conditioner
Ruud UBHC-21J18SFA blowing only "luke warm" air at best
That's crazy, we're having the same problem.  Turns out there was a wattage restrictor in the furnace that was switching off 3 of the 5 heating elements in an attempt to save energy.  Basically, the restrictor was sensing that the incoming air was warm, so only 2 of the 5 coils should be needed to heat the air.  Well that wasn't enough and we just sat with the furnace running all day long struggling to reach the 70 degree setpoint.
This is something a technician can diagnose in a few minutes, but not the sort of thing a DIY'er should really handle.
Dec 22, 2008 | Ruud UBHC Air Conditioner
Central Air not cooling properly
This tubbing carries the refrigerant. The small line is flowing to their inside air handler. If the line is hot it is an indication that the outside unit is not able to release the heat. The most common reason is that the coil (looks like a car radiator) is dirty or plugged. This can be cleaned with a brush or sometimes a garden hose. They do make acid type cleaners for doing this, but the use of the acids are restricted in some areas.
By the way the other black pipe should have a larger copper line behind the black insulation. That line should be cold and sweaty like a nice glass of ice tea:)
Jun 26, 2008 | Carrier 36KCARMS Air Conditioner
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
419 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
