Question about Norelco 3805 XL Electric Shaver
Norelco 3805 XL Battery Replacement
What type and size screwdriver is required to access the inside of subject shaver to enable battery replacement?
  • Anonymous Aug 25, 2008
    On the Norelco 3805 XL. After you get the screws out how do you get the case open. Also can an average Joe replace the batteries. Thanks
I was able to open mine with a 2.4mm slotted screwdriver from one of those mini-screwdriver sets you can get at the store for a couple of bucks. Be aware that the batteries are soldered to the circuit board in this particular razor.
Posted on Jul 20, 2008
Replacement blades
Philips norelco HQ56 replacement heads for men norelco 3805xl electric shaver replacement parts refill.
norelco 3805xl replacement heads
Feb 06, 2014 | Norelco 3805 XL Electric Shaver
I need to change the battery in a norelco 7864 xl, how to do it?
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Mar 13, 2011 | Norelco Health & Beauty
Need instruction on how to replace battery in norelco xl 8825
You will find the correct battery type for model 8825XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 06, 2011 | Norelco Spectra 8825 XL Electric Shaver
I NEED HELP REPLACING THE NI-CAD BATTERIES ON MY SPECTRA 8865 XL
You will find the correct battery type for model 8865XL at shaveroutlet.com. See link below.
Jan 12, 2011 | Norelco Health & Beauty
The battery dies with three green lites still showing. How do I reset the battery memory to get a full charge, and the flashing red lite when low ?
This problem indicates that the battery is worn out and needs to be replaced. You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
Dec 29, 2010 | Norelco Quadra 7865 XL Electric Shaver
How do I change the batteries in my Norelco 3805 XL rechargable shaver?
You will find the correct battery type for model 3805XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the 4 screws. You may need to extend the long hair trimmer to get to two screws. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Nov 22, 2010 | Norelco 3805 XL Electric Shaver
Where do I find replacement heads for this razor??
Norelco 3805xl electric shaver replacement heads is Norelco HQ56 shaving heads replacement parts.
Aug 24, 2010 | Norelco 3805 XL Electric Shaver
How do you replace the batteries on a 5842 XL? Is a special
Sure, the batteries can be replaced. Some soldering is required. If you are capable, you can do it yourself or you can have it professionally done. shaveroutlet.com offers the batteries or repair service. See links below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
If you decide to have it professionally done, you can simply purchase the repair service from the website and follow the instructions for sending it in to the company.
If you do it yourself, you will need toremove the two screws on the back of the shaver to remove the back cover. You will the see the batteries andwhere they are connected to the circuit board.
You may find it easy to use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board2_bing.gif. You can use a small flat screwdriver or similar object to do this. This allows the old batteries to be removed but leaves their tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 21, 2010 | Norelco Reflex 5842 XL Electric Shaver
Norelco 3805 XL Electric Shaver Logo
827 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
