Question about GE Washing Machines
My ge washer WLSE4210 made very loud noise for a couple of loads and now will not spin.
  • 3 more comments
  • anbet1002 Jul 19, 2008
    belt is in good shape
    The belt is in good shape.
    belt is in place
    loud clanking noise. agitator turns, just no spin. if you take clothes out it spins, but makes the loud noise
  • anbet1002 Jul 20, 2008
    Could the spin bearing be worn out since I hear a loud noise during the spin cycle. More than 2-3 articles of clothing, no spin at all. Or could it be the clutch? Either way is this something that can be easily replaced?
    Master:
  • 382 Answers
This is Due to temperory overload of the motor ,due to which the loud noise comes!..The noise is actually the freon rumbling thru the coil. The tech shouldknow how to remedy this, But all techs are not created equal! Afterremoving the rear cover, there is a copper tube exiting the cabinetfrom up above. It goes into a fat tube that is held to the side of thefridge by a metal bracket. Unclip that tube from the bracket, and CAREFULLY,bendthis tube toward the front making it rest horizontally. Be sure thistube is not touching the others. This will fix that noise!
Please reply back for how things turned on or for further help..Thank you!!
Regards!!..
Posted on Jul 19, 2008
  • Natesan Sabesan
    Natesan Sabesan Jul 21, 2008
    Hello again,
    Please dont worry or bother much as this problem can be easily solved,So please call for a service person to check your washer who can get it done perfectly for you buddy!!..
    Thank you!!..Regards!!.. :)
  • 2,427 Answers
See if the gears on the drum are broken (just a suggestion, not a solution)
  • Rishi Roshan Ali Jul 20, 2008
    that could be , try turing it with your hands and see if its rouugh or hard at certin points
    the bearing is easily replaced providing you dont use excessive force and break something
    Scholar:
  • 101 Answers
Can you describe the noise? Something may have jammed in the bottom, like a coin. See if you can turn the basin manually and pinpoint where the noise is coming from.
    Genius:
  • 2,028 Answers
Check the belt that drives the wash tub. It's at the bottom of the machine.
  • GE Master
  • 19,396 Answers
Check the motor belt that is not out of place.
  • Ginko
    Ginko Jul 19, 2008
    Check also that was not overloaded try distributing the load.
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Ge washing machine glwn5050mows loud spin noise
Replace the "tub damping straps" on the unit. Here are the parts to order and the is a video on that same page to show you how to access it. I think there are 4 straps on that unit.
Nov 20, 2013 | GE Washing Machines
Will not spin. Makes an loud noise like its trying to spin but doesn't...
Could you please describe the problem you are having a little better?
Nov 24, 2012 | GE WJSR2070B Top Load Washer
Noise during spin cycle
what noise is it making, it may just be off balanced
Jan 17, 2012 | GE WSXH208A Front Load Washer
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
When in the spin cycle it now makes a horrendous noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
Machine making a very loud noise when it spins
Sounds like the bearings are broken and it may need a major repair. You may need to consider to buy a new washer machine.
Oct 10, 2009 | GE WBSR3140DW Top Load Washer
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
