Question about Microwave Ovens
Turntable not turning all the time
Kenmore (2002) model# 363.62709200--turntable rarely turns
  • 2 more comments
  • hubbuh48 Jul 21, 2008
    Going to check for 21v at plug to motor.
    Not where I plug in the microwave to the house 110 v, where the tt motor is plugged into.
  • hubbuh48 Jul 23, 2008
    Continuity good for motor, 21v AC at plug for motor. Guessing mechanicals in motor worn out. Ordered new motor ...I'll keep updating.
  • hubbuh48 Jul 25, 2008
    New tt motor arrived today, installed and she's up and running. Thanks for the help.
  • Microwave Ovens Master
  • 9,098 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the motor cover off with snips, then use a screw when reassembling it.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
  • 2 more comments
  • William Miller
    William Miller Jul 21, 2008
    Normally that should be 120VAC, so be careful.
  • William Miller
    I didn't find model 363.62709200 but I did find 363.62709300 at the Sears site.
    Microwave turntables normally run on 120VAC, but you are correct. In this case the motor is run by 21VAC!
    So it may be an issue with the low-voltage transformer or the turntable motor relay or the motor.
    Still be careful. Good luck!
  • William Miller
    William Miller Jul 23, 2008
    I've dug a little deeper. This is similar to JVM18xx series GE-branded models.
    The 21VAC for the turntable motor is actually derived from a winding on the cooling fan motor.
    Since you've got steady 21VAC at the TT motor, I'm sure it's bad.
    As I suspected from the beginning.
  • William Miller
    William Miller Jul 25, 2008
    Good job!
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
How to install turntable motor in kenmore 72169072900
You can find helpful exploded views and find parts by entering your full model number (72169072900) at the Sears Parts Direct Web site.
Remove the glass tray and turn the oven on it side to get to the bottom base plate.
If you look at the diagram titled "base plate parts" you'll see the access panel on the bottom in the center that has to be removed to get to the turntable motor screws.
On some models, you have to cut the metal strips holding the panel in place, then during reassembly use a screw to reattach it. In some cases, the cover has to be rotate 180 degrees before reinstallation.
You then unplug the connectors on the turntable wires, then remove the screws holding the turntable motor, gently lift it out and also ease the turntable off the motor shaft.
Jan 29, 2013 | Kenmore 62642 / 62644 / 62649 Microwave...
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Turntable on Kenmore Elite will not turn?
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
If you don't have your owner's manual, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
That's where you could also order any needed parts and find handy exploded parts views.
Jan 04, 2009 | Kenmore 63792 Microwave Oven
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Nov 29, 2008 | Kenmore 63792 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
