No burner connected - Computers & Internet
  • wigland Jul 19, 2008
    when on wmp and trying 2 burner a message saying connect burner and restart is above the burns list please help
  • 2,794 Answers
Go to my computer and move the mouse over to the CD drive. Press the right mouse button and select properties. Go to the CD recording and enable CD recording on the drive.
You might have to adjust your CD speed settings to get it to work.
Posted on Jul 19, 2008
Lower burner doesn't heat up
do you get 230v across the 2 terminals when on? could be a bad solder connection on the underside of the relay board.
Jan 30, 2014 | Thermador SM272 Electric Double Oven
Bottom burner won't heat up
shut the breaker off to the unit. if the bottom burner is exposed remove the screws at the back of the burner and ease the burner out. there will be a wire connected to each side of the burner. remove both of the wires and test the connections of the buner for resistance with an ohm meter if open you need a new burner if not it could be a control. this is assuming your range is electric not gas
Mar 27, 2012 | Ovens
I need help finding out why my computer says no burner connected when ive burned disc from my liteon driver before from windows and now when i go to burn it say connect burner when ive checked the...
sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
Jul 27, 2010 | Lite On SOHR-5238S CD-RW Burner
GE JB900 burner does not work. Indicator lights up but no heat. Worked a couple of weeks ago. Warming burner doesn't work either. Other burners ok.
Sounds like you need to replace the burner, or the wiring is burned. Have you checked the connection between the burner and the oven? They should be clean and fit tight, no burn marks. Burn marks mean loose connection.
Mar 30, 2010 | Kitchen Ranges
WHen I try to burn a cd it says connect a burner
check whether your burner is properly connected or not.
if it is properly connect then the software your are using for cd writing is not compitable with your burner.
Aug 18, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
It says for me to connect my burner
get an external dvd burner,it connects via an usb cable
Jul 01, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Front burner was replaced -- still won't work -- how do i open the top of the range to see if a wire is not connected
most likely you burner block is bad just use a putty knife to pry under the top it should lift up like a car hood check the burner blocks for burn thru or melted wires. UNPLUG UNIT FIRST
Feb 26, 2008 | Hotpoint RB757 Electric Kitchen Range
Have you installed drivers of your burners if not than install drivers and it will solve your problem or you might have not connect your burner properly. If this is not new burner than your burner needs to be repaired or your USB is not working
Nov 06, 2007 | Sony DRX-S50U Burner
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections.
With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
Jun 17, 2017 | Kenmore 91112 / 91114 / 91117 Electric...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
