Question about Whirlpool RBS275PD Electric Single Oven
RBS305PDB6 My oven displays 350 degree default setting when Bake buttom is pushed. The temp setting would go down even when push "up" arrow as does pushing the "down" arrow. Could you help?
  • 1 more comment
  • Rich209 Nov 09, 2008
    I just started having the same issue with mine. Mr. Fantastic what she is saying is the up arrow on the touch pad when pressed sends the temp down just as the down arrow does. I am guessing that its a faulty touch sensor or problem with the circuit board. If you solved your problem please post what you found.
  • edlynch Jan 24, 2009
    I have the exact same problem. Looks like either the control panel assembly with the membrane switches need to be replaced and/or the microcomputer. Would be nice to know if it was just one of these that needed to be replaced.
  • patlexry Feb 15, 2009
    After using the self cleaning, the temperature will only work at 350 and lower, even when the temperature up button is pushed.
  • 116 Answers
The 350 as you stated is a default set point that you see before you start the cycle. What you should see afterwards (start bake) is the current temperature - which would normally be lower than the set or desired temperature - it will eventually get there
Regards
Posted on Sep 06, 2008
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Oven temperature is offf by 30 degrees
It does vary some by model yet the control can usually be calibratied by;
Pushing and holding the BAKE button until the tempature that is displayed changes to 00 then push the up/down arrows to adjust the temp. +/- up to 35 degrees once ya have selected the ajustment all be it up, or down 30 degrees push the cancel/off button and the change will be saved
Oct 02, 2011 | Maytag Ovens
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
We have a digital controll that is not accurate on the oven temp....off by 25 degrees. How do we calibrate it...as in when it is 350 inside the oven, how do we set the digital control to that temp.
on most modesl this is called a clibration adjustment
most have a code that you can enter into the erc
if you still have your book, it is in the directions
most work this way
push and hold bake for 5 sec
you should get a double 00
then use the up arrows to adjust the temp
if this does not work send me the model number
ill send you the directions
Oct 27, 2009 | Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBS275PD Electric Single Oven Logo
330 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
