Question about Tomtom GO 720 GPS Receiver
Speed cameras audible sound
  • latara3 Dec 31, 2008
    also have same problem, tomtom have told me first time i rang to change voice,second time told me to reset to factory settings both didnt work!
Same problem, the speed camera and red light icons appear on the screen but without any audible warning tone.
Any ideas on how to get the warning tone back, as it was originally working but after a few tomtom updates its gone.
Posted on Jul 24, 2008
How do I disconnect the warning chime?
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
Occupant (Seat Belt) Restraint Audible Chime
Content Theft Pre-Alarm Audible Chime
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Nov 28, 2017 | 2002 Saturn L-Series
First try uninstalling the version you are using and install the latest version 5.2, Then open an .swf file in the player and close the file. Now open the video file you were trying to play. The sound must be audible. Try this solution, if the sound was audible in other video players and not audible with MPCStar player.
May 12, 2011 | MpcStar
Sound is barely audible even on high setting. Is this normal?
Yes I am also having same problem. Kodak M550 is basically still photo shooting camera. It is not video player. If you will play that recording on pc or other any equipment you will hear good sound. It records normal speaking better not best quality.
Nov 19, 2010 | Kodak EasyShare M550 Digital Camera
Our camera makes audible internal noises when in use. Should the unit make any noise when in use?
The unit produces sounds when like zooming or focusing or taking pictures. other sounds are malfunctioning in the unit, get it repaired.
Nov 09, 2010 | Kodak Easyshare C182 12MP Digital Camera
No audible warning when exceeding local speed limits
look on your screens, i think it is on screen 3 there is a picture of a speaker if it's got a X on it, touch it the cross should go out, it is to mute the speaker.
Feb 03, 2009 | 1995 Jaguar XJ6
Camera - Canon Powershot S2 IS (5.0)
This is caused by a bad lens motor, contamination in the transmission, or mechanical damage from dropping. The only fix for this is to have it serviced by Canon or other camera repair facility.
Dec 14, 2008 | Canon PowerShot S2 IS Digital Camera
Sound scratchy
Seems to me that the first thing you want to do is find out if your problem comes from the camera speakers/output, or if it records them scratchy. Take one of the "scratchy" cassettes, and play them on another device to see if it transfers bad audio. If it does, then you're worst off offcourse, more of a repair. If it doesn't you can decide you don't need a repair, as long as it does the job. Good luck
Apr 01, 2006 | Panasonic NV-DS60 Mini DV Digital...
Recorded sound problem
It's possible that you were recording something too far away from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Tomtom GO 720 GPS Receiver Logo
127 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
