Question about Dometic Heating & Cooling
Dometic rooftop camper a/c unit leaks after running for a few minutes, it also leaks when it rains and when the unit is off. Water comes out from several spots in both instances.
Air condition compressor comes on but the air does not get cool. This is a rooftop aircondition for campers.
Posted on Sep 16, 2008
Rpod ac unit leaking
if the gasket is bad it could leak
Aug 21, 2012 | Dometic Rooftop RV Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
I'm purchasing a generator to power the Dometic Duo Therm Brisk Air A/C unit in my camper. How many watts does it draw?
You will need at least a 5000 watt generator to run that and a few lights etc... for the camper.
heatman101
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
T Tair conditioner unit in our camper runs for a
the air filter may be dirty, if thats not it it is the condinser burned up and not pumping freeon
Jun 29, 2010 | Dometic Rooftop RV Air Conditioner
Rv ac unit leaks, even when fan only
Where the pipes enter the building, look carefully there for a bad seal. Use a good quality sealant and block the leak properly. If there is no rain, and the unit is leaking still with the fan on only, then you have an issue with the drain pipe angle or a kinked pipe or a blockage. Suggest you have it seen to by a aircon. technician as that repair is really not easy.(AC will possibly have to come out to rectify problem).
Oct 17, 2009 | Dometic Rooftop RV Air Conditioner
Help, Brand New A/C unit drippin inside camper
they do that its normal operation, you will get varying amount depending on your location and humidity. If it is not balanced or installed right it drips in the camper.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
My dometic RV rooftop air conditioner is leaking on the inside of the camper even after I cleaned the water condensation drain on top of the roof. What could be causing this? The fan is blowing the water...
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
No cold air. Unit runs fine.
yes if it has service ports but if it lee=aked out you need to fix leak first
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Heating & Cooling Logo
527 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
