Can't tape tv program on VCR while watching another show on digital cable.
  • 1 more comment
  • ssoss Jul 20, 2008
    It is wired from the splitter to the VCR and the AB switch and the cable box with a coax cable per instructions from the cable company (Comcast). Thanks.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does the AB switch toggle between the cable box?
  • Tim Babcock
    Are you trying to record the show using the cable tuner box or do you have another coax line plugged into the VCR?
  • 2,794 Answers
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Posted on Jul 20, 2008
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
Taping digital onto a vcr
You'll need to connect the VCR to the converter box and then connect your VCR to the TV. ou can get a diagram showing how to connect everthing at www.dtv.gov; there is a section with publications that has a document on how to hook up your VCR to tape the show your watching or watch one show while taping another.
Mar 14, 2009 | Insignia Digital-to-Analog Converter for...
How to connect a vcr for recording programs
1 - To start with..
Plug aerial lead into the "RF input" on rear of vcr
--> now you can tape programs (providing vc is "tuned" correctly)
2 - Plug a lead from "RF output" into tv's "RF input"
--> now you can watch programs on tv _independently_ of vcr (ie can be watching 1 program & taping a separate one on vcr)
3 - Plug red/white/yellow cable from vcr's "VIDEO/AUDIO output" into tv's "VIDEO/AUDIO input"
--> now you can
1) play a tape in vcr, & watch it on tv
& 2) change what watching on tv via vcr's remote
* Note: This is for analogue terrestial television (aerial on roof), not digital/satellite tv, connecting to stereo, etc, etc (the "more involved " setups)
Feb 03, 2009 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Taping
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
I am having difficulty when I try to program the VCR to tape a TV show that I am not watching. When I go through the nine steps that are outlined in the manual on pages 24 and 25 the TV will tape for me...
if you are useing a cabel box you need to split your cable before the cable box with a two set coupler and run the second cable line to the VCR input and this should solve your problem. if you want to record the chanels from your cable box and not watch a diffrent chanel you can leave it hooked as is and select the chanel you want to record with your cable box tunner and leave it turned on, set the vcr to record channel 3 or 4 which ever is the channel you leave your tv tunner on and record that way.
Jul 30, 2008 | Televison & Video
Taping to a VCR post converter hook-up
cant you just turn the channel on your DCB and then record on the vcr?
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Recording a tv show
Make sure the cables going from the cable box to the vcr are not loose as well as the ones from the vcr to the tv.
Feb 20, 2008 | Zenith ALGB201 VHS VCR
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
