Question about Dell Microsoft Windows XP Home Edition
REPAIR NOT ABLE TO REPAIR WINDOWS XP
  • Rahul Panicker Mar 20, 2009
    Thank you for the help
  • 64 Answers
Are you saying you've tried doing a repair with the install cd? Does it boot? If so, click Start-->Run and type in sfc /scannow in the box, then click OK. You may be prompted for your cd. Then reboot.
Posted on Jul 20, 2008
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
Tip
Windows XP failed to start because of a recent hardware or software change?
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
7. You will need to apply Windows updates after this procedure.
Not a trivial task but it will work. I do this for fun & feedback so 4 thumbs would be nice.
Jim
on Sep 21, 2010 | Computers & Internet
Tip
How to da a REPAIR re-install XP
If Windows XP was preinstalled on your computer, you may need the installation CD to reinstall.Contact your computer manufacturer to make sure that you have the installationCD for a repair installation.
To reinstall Windows XP by starting your computerfrom the Windows XP CD, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
  2. When you receive the "Press any key to boot from CD" message on the screen, press a key to start your computer from the Windows XP CD.
  3. The following message on the Welcome to Setup screen will appear:
This portion of the Setup program prepares Microsoft WindowsXP to run on your computer: To setup Windows XP now, press ENTER. To repair aWindows XP installation by using Recovery Console, press R. To quit Setupwithout installing Windows XP, press F3.
4. Press ENTER to set up Windows XP.
5. Press F8 to agree to the license agreement.
6. Make sure that your current installation of Windows XP is selectedin the box, and then press R to repair Windows XP.
on Jan 24, 2010 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Microsoft Windows XP Professional
Windows could not start, file is missing or corrupt-windows, system 32, config system. to repair file using original setup CD-ROM, select "r" at first screen to start repair. What is this?
Hi !
If you enter in Windows XP set up, below instructions will appear:
1. To set up Windows XP not, press ENTER.
2. To repair Windows XP installation using windows console, press R.
3. To quit set up with installing Windows XP, press F3.
By pressing ENTER means it will repair your operating system and it will delete all your files in hard disk drive leaving nothing to that particular drive or partition.
By pressing R means it will repair your operating system files only and it will not remove your files.
By pressing F3, it will exit the Windows XP set up.
I hope this is helpful and thank you for using FixYa !
Jan 06, 2011 | Computers & Internet
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Hi my everex computer is getting a screen saying windows could not start following file js missing or corrupt:..windiwssystem32configsystem............How do i repair without loosing my downloaded pictures...
Hi, Assuming the OS as XP. Plz follow the below steps.
Yes, you can repair your system,
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
May 23, 2010 | Everex StepNote NC1500 Notebook
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
I can't start my windows there is a error message
Well you need you windows XP CD to fix this problem. You have to boot to your Windows XP CD and repair the operating system. Any windows XP CD can be used to repair your computer. If there's none. Call the manufacturer of the computer and see if they can send you one.
Feb 10, 2009 | Microsoft Windows XP Professional
My laptop is not switching on
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Oct 22, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
57 people viewed this question
Alun Cox
