Question about Samsung RS2630SH Side by Side Refrigerator
Mullion between freezer and refrigerator is extremely hot.
The very front of the wall that separates the refrigerator and freezer is very hot to the touch. I am talking about the part that the rubber gaskets on the doors touch when you close it. I have been told that there is a "mullion heater" in most side by sides to make it seal better, but I don't think it should be that hot. Thanks, Jaye
  • miamin Aug 04, 2008
    I have the same problem. My refrigerator front side wall that seperates the sides gets burning hot. The outside side of the freezer is burning hot too. When ice-cream put in the freezer touched the wall, it melts in the freezer. Got the motor and fan replaces, that did not solve the problem.
    Scholar:
  • 50 Answers
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Posted on Jul 19, 2008
  • rfeiler
    rfeiler Aug 08, 2012
    This area under the fridge was clean, no dust bunnies. Some water in tray but it was not full or overflowing. Any other suggestions?. Especially since the wall is split and cracking turning brown in some places.
Hot center wall in refrigerator
This is more likely to a defrost heater sticking on and not turning itself off, could be either a timer, board or defrost temperature sensor issue
Apr 03, 2014 | Refrigerators
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Interior wall of unit gets extremely hot
If you are talking about the wall that runs between the freezer and the fridge where the door gaskets actually touch. The answer is no. It should be warm though.
What can cause this is the fan that is located at the rear not operating or dirty coils under there. Check the fan it should be operating when the unit is in the cool cycle, if it is not then it will need to be replaced. And clean the coils. This will help.
May 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid bottom drawer freezer is making frost or ice flakes inside. Why?
If frost is front towards door then the seal is not sealing well . Use a hair dryer on portion which is not touching cabinet . Also check for split somewhere on gasket & if found , replace gasket . If frost on the rear wall of freezer , then a defrost problem could be starting in which the fridge section would be warming up . However , bottom freezers are known for their gaskets not to seat properly .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
1,829 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
