Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissel pro heat
The soap mixture doesn't get pumped out, the red swivel turns OK, water comes out of both floor & wands OK, vacuum sucks up OK, tks Wally
  • Anonymous Mar 28, 2014
    The rug mode works when swiveled to the left but cuts out when swiveled to the right.
    President:
  • 1,673 Answers
Mostly likely there is a problem with the valve at the bottom of the soap bottle. Try replacing it.
Posted on Jul 20, 2008
Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a bissell pro heat and the soap dispensor puts out way to much too fast. It fills the bladder with bubbles in seconds. How do we fix?
There is a setting on the unit, near the floor. You can set it to spray HI, LO or ONLY Water. You can set it accordingly between settings too.
Hope this info was helpful to you. Good Luck!
Jan 31, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and soap coming out wheel area
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
