JVC TH-A35 System Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible other than to power off
Anonymous
Level 2:
Sergeant:
Novelist:
  • Expert 157 Answers
  • Posted on Jan 30, 2011
Anonymous
Expert
Level 2:
Sergeant:
Novelist:
Answers
157
Questions
Helped
34298
Points
512
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
1 Related Answer
A
Anonymous
  • Posted on Apr 23, 2007
SOURCE: Error message upon powering on
Unplug it for 10 seconds then plug it in again
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
If press eject button,it's showing LOCKED.what can i do?
The Onkyo DV-CP706 changer doesn't seem to complete its boot-up whenever turned on. The console display says "OnkyO DvD" and nothing else. The monitor display indicates "No Disc"...
Hello, I am sorry about you issue. It sounds like your player needs to be serviced. I have included a link to search for an authorized service center. Thank you, Onkyo USA
https://www.onkyousa.com/Support/servicecenterlocator.php
1helpful
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
It shows "Fan Fail" and
Hello
The failure is of fan only, fan may be damaged. It can be replaced with and other fan. take it out, and go for an other same type. If the whole system is dead, it should be due to the fault of its power inverter board, and should be ckecked well. If power board has some trouble, front panel display also will not be there or display will be present, but no other functions, like load disc or unload disc, play etc won't work. From these make sure which part has the trouble and go on. You have pointe out the fault of the fan only here. OK.
My Sony DVP-CX777ES player just opens and closes several times upon powering up. Then it stops and I get an error message that reads "C 32 00." Then it turns off.
Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem.
Hope this will help.
Thanks.
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
LG RH1999H DVD Recorder
I did try removing the Hard Disk from the recorder and did a diagnostic and fix-disk using Ontrack software. Ontrack showed no structural and physical defects on the hard disk. I replaced the hard disk in the recorded and guess what! Please wait, please wait, please wait, please wait...................................
How to unlocked region code
XD-DV480 Multi-Region: Converting the player to an alternative region:
  • Supply power to the unit and power on from standby mode via the remote
  • Wait until No Disc is indicated on the fascia
  • Now press Pause followed by 3, 4, 2, 2, 9 and then 2
  • The display should now read CODE
  • Now press 0, 0 for region free or 0 then 1 for region one, 2 for region two, and so on (Note: RCE discs will require specific region set)
If the above modification fails to work then the alternative method below may work:-
  • Connect the DVD player
  • Use the Remote Control to turn power on
  • Wait until No Disc appears
  • Press Pause and type the following code, 8, 9, 2, 6, the display will show "CODE__"
  • Within 5 seconds press 00 for all regions
  • Press Pause and Power
This should work for you.
2answers
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
