Question about Bionaire BT45RC Tower Fan
Cleaning inside the fan
Since the fan has started sqeeky noise, we need to clean up inside.
We unscrewed to try to open and uncover, but we couldn't uncover it. How can we reach inside?
Thank you in advance.
  • cyberworkx1 May 02, 2010
    Has anyone found a replacement bushing assembly?
    I have 2 of these Bionaire fans, and both have the same issue, on one the bushing must have froze, and ripped the rubber mount.
    This sounds like a manufacturing problem, or maybe a built in replacement and sales generator for Bionaire???
Unplug the unit from the wall for safety. Remove the two screws in the upper hand grip recess (upper back of the unit). The two screws must be completely removed (not just loose and setting in the holes). Once the two screws are out, the back half of the fan cover can be slid downward (some amount of force is needed to unsnap the two halves from each other but be careful since the parts are all plastic and can possibly snap). Once the back is unsnapped from the front, you can lift the back half away from the front half and the inside parts are now accessible. I have found on my fan that it is the top fan shaft / bushing that is causing the squeaking noise that so many have complained about. I have found that periodically lubricating the top shaft/bushing will make the fan sound like new again - for a while. Every 2 - 3 weeks I need to clean (wipe off old lube) and re-apply fresh lube).
Posted on Jun 07, 2009
How do i take apart my lasko cyclone fan to clean the inside of it
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
Aug 09, 2014 | Lasko 3510 cyclon Floor / Box Fan
My gateway ZX4351 is too loud.. How do I open the case and clean the fans?
Depends if the fan's can even be cleaned. There will probably be several screws you will need to remove on the back, along with the stand. The edges may need to be pried open, preferably with a plastic pry bar so you don't damage the case. Once the case is open unscrew the fan and see if it has a rubber stopper in the center, possibly under a sticker. If it does then you can open that and add a drop or two of sewing machine oil and it should be quiet after. If it isn't then I'd just replace the fan.
Feb 02, 2013 | Gateway ZX4351-47 21.5-Inch All-in-One...
I buy an HP pro book 4520s but its have huge noise from the Fan and getting too much heat and then when i play a game on it turn off
you can try getting a can of compressed air and blowing out the vents. if this doesn't work you will need to open the case and clean the vents from inside. clean the fan and ideally remove the heatsink and apply thermal paste to the processor where the heatsink sits.
Mar 10, 2012 | HEWLETT-PACKARD HP ProBook 4520s Notebook
How do I clean the fan? It's making a loud noise.
Hmm if u can open up ur computer then u can clean the fan ur self.Else if u have a Compressed Air Can,u can try spraying Compressed air to ur Fan.However even if u do so,the dust will be inside the laptop.So best is to take the Laptop to a service Center if u r not an expert in removing the back of the laptop
Dec 07, 2011 | Televison & Video
Fan has started to run constantly and very noisily can i fix this myself
  1. Clean the CPU fan.
  2. Clean the power supply fan.
  3. If the noise persists and can be narrowed down to the CPU fan, replace the CPU fan.
  4. If the noise persists and can be narrowed down to the fan inside of the power supply, replace the power supply.
    Note: Due to safety concerns, it is never recommended to open the power supply and replace only the fan. I always recommend that the entire power supply be replaced instead.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | HP G70-460US Notebook
My computer started making a loud noise that will not stop. I am not sure if it is the fan or hard drive. The computer seems to be working fine. Any idea what could be making the noise?
In order to confirm the problem.. first of all turn off the pc and unplug the power cable from the back of the pc.... get a Philips head screw driver and open the chasis.... plug in the power cable and see where are you getting the noise from .... there are three fans namely one on the processor, the other a cooling fan and the last would be inside the power supply.. if its inside the power supply nothing can be done ... if its the cooling fan noise .... try to clean the vents or the cooling fan with the help of the dry cloth and if its the processor fan then its a serious issue ....
Apr 12, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
It won't read that there is a disk in the drive. When I put the disk in it makes a lot of noise and sounds like it's trying to start but in the end it quits and doesn't do anything.
If this happens even if you try to play several cds, then lens inside which reads the CDs needs cleaning. Try using a CD cleaner and let that spin inside the cdrom for like 30 seconds. Then try playing the a cd again. If it still fails to read them, you may need to manually clean the lens inside. Open the casing and unscrew the plastic plate the covers the lens. Get a q tip or a cotton bud and damp it with alcohol. Gently wipe the lens' surface and let it dry. Then return evrything back and try playing those discs again.
Hope this helps.
Oct 30, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Fan noise, How to resolve???
The noisy fan in your PC, it sounds like (no pun intended) you may need to power-off PC, open it up, and give it a good cleaning with a vacuum cleaner. If possible, after you've got her PC open, and before you clean it, turn it back on so you can figure out which fan is causing the noise problem (many PCs have more than one fan). If it's the CPU fan, then you're going to want someone who is comfortable and experienced with removing it and replacing it with a new one, because it is EXTREMELY important to get 100% physical contact between the CPU chip itself and the cooling fan/housing that is attached to it, or the CPU is going to overheat and destroy itself within seconds of being turned back on.
If the noise turns out to be from a normal case cooling fan (3-5 inches across), you can try cleaning it really well to remove any dust, and see if that fixes the problem. If not, you can buy a replacement fan of the appropriate size at pretty much any PC store for $5-$20. It takes 5-10 minutes to unscrew the old fan and install the new one, and just use the same electric wire from the old fan for the new fan.
If the noise turns out to be from the computer's power supply, you cannot repair it, so it needs to be replaced. I would recommend either replacing it yourself, or having someone who has done it before replace it for you
Mar 22, 2009 | Toshiba Satellite P205-S8811 Notebook
LG Refrigerator/Freezer Model GR-762DEQF
you will need to replace the fan the reason it stops it the door switch needs to be closed for the fan to operate. with the door open press the switch and see if that is in fact where the noise is coming from if so it sounds like the bearings are going out
Feb 16, 2008 | Refrigerators
Bionaire BT45RC Tower Fan Logo
2,282 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
