Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
Wash cycle codes
Flashing code "F, H" don't have manual to look up the codes, couldn't locate manual online.
  • 5,911 Answers
Click on the following link for a detailed explanation of the "FH" error code:
Read through the information thoroughly and you should be able to determine the cause of your problem. I hope this helps you.
PS There should be a tech sheet located inside the washer that explains all the error codes and how to troubleshoot. It should be located either behind the bottom panel under the door, or along the interior cabinet wall somewhere.
Posted on Jul 19, 2008
The machine won't start and flashes error code E91. What is your recommendation for a fix. Thank You, Jim
Buy a repair manual for the machine after checking the user manual that came with machine. If no manual, then purchase a manual online. Search your machine's name and find it online.
Apr 26, 2016 | Washing Machines
Why isn't my front loader running through its wash cycle?
You are probably getting a flashing light on the front panel. The flashes are a repair code. Count the flashes and look up the code in the back of the manual that came with the machine.
Apr 25, 2015 | Washing Machines
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Lights flashing during cycle
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.
If helped click helped.
Apr 27, 2013 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Wirpool duet washer.After wash cycle and rinse wont spin and drain water. Wife told me it shows code O2?
Try looking online for a manual for this machine. Online companies allow the search/download of manuals for most things these days. Good luck
Aug 24, 2011 | Whirlpool Washing Machines
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
You can download the online repair manual in the below link$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F01 Error code
most likely suspect main control bd
Apr 11, 2008 | Kenmore 46462 Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
81 people viewed this question
Sal De
 Brian Main
Brian Main
