Question about Refrigerators
The freezer of my magic Chief Side by Side is draining the water from the frost free cycle into the bottom of the freezer. It is running out the door and also poooling in the bottom of the freezer and building up ice.
    Scholar:
  • 50 Answers
There is a drain tube underneath the evaporator coils that has probably froze over. You'll probably have to take the evaporator cover off to access the drain area (the back wall of the inside of the freezer). You need to clear as much ice as possible from the area, then use hot water to melt the ice in the tube. There might also be a block in the tube (like a pea or corn) so you may still need to run something through the tube to clear that. Some things that might help prevent this in the future (other than not spilling a bag of frozen peas) would be to make sure the frige is level side to side and tipped back slightly, this will help the water run towards the drian. Tipping it back also helps the doors swing shut so you don't potentially leave a door. Also make sure the freezer is not too cold. Place a thermometer in the freezer and set the temp at between 5 and 10 deg above zero. Any colder will only freezer burn your food faster and cost you more electricity and put more wear and tear on the frige. You have to wait 24 hours between adjustments and check the temp after the doors have been shut for 6-8 hours (like first thing in the morning).
Posted on Jul 19, 2008
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 07, 2011 | Magic Chef Refrigerators
Water is leaking inside my lower compartment. Water comes from beneath the freezer...help me...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | Magic Chef Refrigerators
Build up of ice on bottom of freez
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE GSF25XGRWW 36" 25.4 Cu. Ft....
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Small puddle of water won't drain
make shure the strainer is clean
there could be a partial blockage in the pipe
make shure the drain pipe isnt kinked
Mar 18, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Sep 12, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
