Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
GE PROFILE FREEZER PFS 22 SISBSS
FREEZER WARM 12 DEGREES AND CONDENSER FAN TURNS VERY SLOWLY
  • steelerman21 Dec 10, 2008
    Same problem with mine.They replaced the control board. Also the door catch for the French doors has broken THREE TIMES NOW. Glad I bought he extended warranty. Service guy says GE is aware of the design flaws.
Hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Posted on Aug 14, 2008
I had my mother board ( control board) replaced to sovle the problem. There is a factory recall on them and there was no charge.
Posted on Oct 07, 2008
    Scholar:
  • 50 Answers
These condenser fans are DC motors, so they will spin at what ever speed the control board tells it to. Chances are the fan is ok. It's probably a bad control board. Sorry, those are very expensive!
Posted on Jul 19, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
May 03, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile freezer is reading 22 degrees F. I have set it to 0 degrees and it doesn't appear to be working.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | GE Refrigerators
Hi, I have a GE side by side GSS23LSTA refrigerator The last few days it has been running constantly. The refrigerator side temperature is fine at 35 degrees, but the freezer temp is staying at around 12...
Hi Mark and welcome to FixYa, I am Kelly
Touch the front of the unit where the doors close and feel if it is very very warm to the touch. If it is very warm to the touch... here are the prime suspects:
1. condenser coils covered in lint
2. condenser fan not running or running slow.
An easy way to determine if there is a condenser fan or coil fan problem is to simply direct a floor fan at the base if the refrigerator. If it cools down substantially in an hour.... there is a problem with the coils being clogged or the condenser fan not running. If that makes no difference... before opening the back of the unit... inspect the back wall of the freezer compartment for any signs of ice build up. If you see ice-build up.... unplug the unit.. remove freezer contents and direct that fan into the freezer compartment for just over 2 hours. Then return the unit to normal service.... If the temps come down to normal... for 2 - 3 days then start creeping up again... you have an automatic defrosting problem.
Forgot to mention... make sure the evaporator fan is running at full speed.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica top freezer: freezer and fridge have been too warm all day. The freezer is 40 degrees and fridge is 46 degrees. Adjusting the temp does not help. Please help
Hi,.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 26, 2010 | GE Profile Arctica Stainless Steel Top...
My GE Profile (PFS22SISBS) freezer not getting cold enough
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 18, 2010 | GE Energy Star PDS22SIS Stainless Steel...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
1,275 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
