Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Whole house attic fan
My 30" whole house attic fan won't start. When you flip the switch on, the motor buzzes, if you spin the blades manually the motor runs. Do I need to replace the starter capacitor or the motor?
Thank you,
    Novelist:
  • 124 Answers
A simple capacitor tester will tell if the capacitor is bad. turn off power, label wires and where they go and test cap after discharging it . to discharge simply connect the terminals together once its been removed( you can use an insulated screwdriver to connect them and discharge any stored voltage) and then touch meter leads to each set of terminals and read the microfared output. the setting on the meter is usually labeled uf. or you can take it to the electric motor shop and let them test it. it has a rating value labeled on the side. usually it has to be within 10 percent of the rated value or its bad . if the cap checks good then the start winding in the motor is probably bad or weak, then a new motor is called for, it is usually not worth the time wait and trouble of getting it rewound etc. take the old motor out and label and measure exactly how and where it was mounted. label and make diagrams. saves a lot of time reassembling exact as it came out. turn off the power , check it with a meter to be sure , short it with a screwdriver to be sure the meter works ,and then treat it as if it was still hot as much as possible when you work on it.
Posted on Oct 09, 2008
    Novelist:
  • 130 Answers
Capacitor
[from an engineer]
Posted on Sep 29, 2008
We have recently purchased an older home, built in 1931. There is a whole house fan in the attic that we would like to get working again. We do not know when the fan was installed or who made it - however,...
What and interesting situation. I have seen installations like what you describe, but not in a residential application. Industrial applications that had very high ceilings and in very old apartment buildings, But not in single family resident. I suspect, that the previous owners "acquired" it through unusual circumstances.
In any event, 1/3 horsepower electric motor is not that hard to find. The real key is getting the right rotation, so the blades will pull the air up and out instead of in and down. Remounting a new motor coupled with the right pulley size for a fan belt ,can control the speed of the fan. Rarely are hold house fans direct drive. Which may be the case with yours, I don't know.
As far as a new 1/3 Hp motor is concerned, I would recommend Grainger Industrial Supply
http://www.grainger.com/Grainger/wwg/start.shtml. They have locations throughout the country and their staff is knowledgeable. They can probably help you with designing a belt & pulley system, to control the speed, if necessary. Keep in mind, 2-speed motors are also available.
Redesigned properly, you can do away with that horrendous shaft.
Hope this helps steer you in the right direction. If nothing else, food for thought.
Apr 28, 2011 | Heating & Cooling
How do you operate the whole house fan in order to save heat loss
make covers for garage opening with hinges open in summer close in winter .
Oct 07, 2009 | Heating & Cooling
I just bought a new motor and installed it but now
Centrifugal force.....If you replaced the motor only and not the blades, the blades are likely out of balance or possibly bent. Check for wobble and to see that the shaft is fitting tight inside the blade collar.If there is a bushing on the fan blade or shf itself, check it for play as well
Sep 13, 2009 | Dayton (2C373) Fan
Attic fan problem
The belt may be slipping and reducing the flow of air
Aug 16, 2009 | Heating & Cooling
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Attic fan stops running after one hour
I need to verify you have adaquate air flow, to cool the motor. If you have a window open, and the crawl hole open is there enough air flow into the the attic? It there is enough air flow and it still stops after about an hour, does this unit have a humidistate and a temperature switch on the housing or extension.
If all the switches are working correctly then I could be the motor overloading/heating shutting down and then reseting.
InMrFixIt
Oct 12, 2008 | Ventamatic Direct Drive Whole House Fan...
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
872 people viewed this question
Top Ice Kitchen Appliances - Others Experts
howard thompson
Tom Chichester
Marat Brikov
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
