Question about Dishwashers
Panel doesnt work on dishwasher
Looking for code on frigidaire dishwasher
All i did was unplug dishwasher for 30 mins.and the code reset it self.
Posted on Jul 21, 2008
Frigidaire dishwasher has blinking codes. we replaced the main control panel and the pump is and heating element are good What next?
Thank you for your inquiry, Geri!
From the information you have provided your Frigidaire dishwasher is blinking codes and you have replaced the control panel. What lights are blinking on your dishwasher? Could you provide me with your model number please? The model number can be found on the serial tag which is located on the inside left hand tub wall. With that information I would be able to assist you further. -Matt
Mar 07, 2015 | Frigidaire Dishwashers
How do I find out the error codes?
Good Afternoon Delia Collins, thank you for your post!
Based off the information you have provided your Frigidaire dishwasher is flashing an "ER" error code on the panel. Typically, the "ER" stands for an error code sometimes to help clear out a false error code you can perform a reset on your dishwasher. In order to do that you would need to disconnect power from your dishwasher for approximately ten minutes.
If you continue to experience an issue with the error code I would recommend contacting a technician for proper repairs. The technician will be able to properly diagnosis your dishwasher and this will help you to avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Nov 05, 2014 | Frigidaire Dishwashers
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
Why are the lights on the far right of the panel of the Frigidaire gallery dishwasher model #GLD8958A52 ?
Hi friend, thank you for your inquiry!
I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
Oct 16, 2014 | Frigidaire Gallery 24" Built-In Dishwasher...
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
I have a frigidaire dishwasher FDB2415LFSO white and would like a stainless steel finish. Are there door panels available for this model?
yes / when changing to ss from white . most people wasnt the black control panel . as it looks best . the cost of the panel and stainless . is costley . and inless dw is newer model . most would look at the cost of a new one .. hple this helps mm
Dec 08, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher PLD 3465 REC I cannot reset the display panel. I took the kickplate off which was supposed to have the code for the reset but it had nothing related to reseting the display panel. It is stuck on...
Putting the unit into service mode will reset the the display. Look at the instructions behind the front panel. If the unit fills and does not wash, the wash motor may not be working.
Sep 05, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
