After using the aliment utility several times I am unable to get the printer to line up. It now has a double image
  • 6,487 Answers
Did you try cleaning your printer cartridge or nozzle using the utility?? By the way what's the brand and model of your printer??
Posted on Jul 19, 2008
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
Cannot add r1800 to Leopard
Important OS X pre-installation instructions: The Macintosh OS X driver found on the CD provided with your product is not intended for use with Intel-based Macintosh computers. If you have already installed the OS X printer driver provided on your product CD, please follow these important instructions before installing the "epson11769.dmg" file:
  1. Open the OS X "Printer Setup Utility".
  2. Select the "Printer Setup Utility" tab and click "Reset Printing System...".
  3. Click the "Reset" button.
  4. Restart your computer.
  5. Install the downloaded "epson11769.dmg" file.
Installation instructions (some of the following steps may not be necessary):
  1. Download the file.
  2. Double-click the downloaded file to create a disk image on your desktop.
  3. Open the disk image.
  4. View the included "Readme First.pdf" document for important information.
  5. Double-click the installer icon to begin the installation
link to driver
disconnect usb, delete all old attempts, do not connect untill prompted by install
Dec 04, 2007 | Epson Stylus Photo R1800 InkJet Printer
PRINTED IMAGES SLIGHTLY OUT OF FOCUS SINCE CHANGING PRINT CARTRIDGES
Most printers have a "UTILITY" program that will let you align the print heads. I would start there to correct the problem.
Sep 22, 2014 | HP Deskjet 3052A Wireless e-All-in-One...
I get a double image with my Epson c120. I replaced the color ink cartridge for about $49 in order to be able to print black and white text but I get this almost unreadable output. Any suggestions?
try doing print head cleaning.. the feature is under the printer properties , utilities tab... then once done.. print a copy of nozzle check..see if there is any missing line..
May 28, 2010 | Epson Stylus C120 Color Printer InkJet
HP Photosmart c7180 unable to scan since Windows 7 computer
go to following location and try to scan and tell me if it is scanning fine or same issue.
c:\program files\hp\digital imaging\bin in bin folder locate following files. /* in 64bit operating system inspite of program files look into programe files(x86).*/
1.> hpqscnvw
2.> hpqscnappi
3.> hpqdstcp.
4.> hpqgrpky.
double click on any of these it will start scanning.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
My printer is printing double lines
Select an image to print.Click 'Printing Preferences'. Click the end tab 'Services'. Click 'Service this device'. Then you can click to align the cartridges and clean them too.The device will do it for you and you can check at each stage as a test sheet will be printed :0)
Oct 11, 2008 | Office Equipment & Supplies
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printed lines shift to left and double images
Are the lines vertical? Have you tried to align the printheads? This can be done using your printer's installed maintenance software.
Mar 28, 2008 | Office Equipment & Supplies
Photos they come with a yellow line through it
This kind of thing happens to me a lot when my cartridge is running out of ink, and if it has been doing it since you first used the cartridge it may just be a dodgy cartridge.
However, this printer doesn't print the clearest of pictures even at the best of times. If when you do the alignment check you find that in the selection with the least obvious lines, the lines are still pretty obvious, then your printer's just not very good.
Mar 20, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
