I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Comments:
Jul 20, 2008
- The zoom motor works when I use the conversion mode but not on the switch. Thanks you for the suggestions and we will contact customer support at panasonic.
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed. ----------------------------------------------------------------------- Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera. 2. Press "MENU SET". 3. Press the up arrow button. 4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button. 5. A sub-menu screen should now pop up, select and set "OFF".
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped. ~If the camera has been thumped or banged. ~If while zooming, the lens was obstructed. ------------------------------------------------------------------------------- The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com. -------------------------------------------------------------------------------- My best advice would be to contact panasonic customer service.
I try to take a pic but it says 'no memory space on memory stick' ...even though I just deleted...
(More)
I try to take a pic but it says 'no memory space on memory stick' ...even though I just deleted photos via the computer...?!?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
