Question about Tascam DP01 All-In-One Recording Package Microphone
Microphone jack I can't get any response out of my microphone jack
    Sergeant:
  • 243 Answers
Is it selected/cued
Posted on Aug 22, 2008
My head phone works very good but the microphone doesn't work
When you say headphones do you mean the music headphones, like speakers, because they go in the headphone jack in the computer while microphones go in the microphone jack. The microphone is normally a pink color and the headphone jack is normally green. If you already knew this try wiggling the microphone to see if there is a brake in the wire, if that dose not make it fissile in and out then its something wrong with the microphone its self and should be replaced
May 03, 2011 | Logitech (980240-0403) Microphone
How to connect mike in computer
  • Look for the sound card on the back of the computer. This will have a 15-pin connector and several colored jacks.
  • Locate the microphone jack. Although some manufacturers will stray from the norm, the microphone jack is typically colored red or pink and/or will probably have a picture of a microphone.
  • Connect the microphone into the jack.
  • Click "Start," then click "Control Panel," then click "Hardware and Sound," then click "Manage Audio Devices" under the "Sound" category. This opens the "Sound" window.
  • Click the "Recording" tab. Here you will see a picture of a microphone. To the right of the picture should be a sound bar.
  • Test the microphone by speaking into it. If the sound bar lights up, then the microphone is plugged in correctly and ready to use. If the sound bar remains gray, then there is no signal. Try another jack on your sound card and repeat the steps to test your microphone. If you still can't get the microphone to work review your computer documentation or contact the manufacturer's technical support.
  • Mar 08, 2011 | Acer Aspire X1200 Desktop PC - Athlon X2...
    Can i work this mic with my computer?
    Yes. You should be able to plug it in it your microphone jack. First, find the mic jack. it should be located right next to the headphone jack. Open your sound dialog. You can find it by right-clicking the volume control and selecting recording devices. Look for your microphone in the dialog. It should have a green tick on it. If it doesn't, select it and click "Set Default". (note: your microphone may not show as a separate entity. if not, select your default microphone and test it by speaking into the MV29. The level should change)somervta.jpg
    Jan 20, 2011 | JVC MV29 Dynamic Microphone (MV 29, MV-29)...
    Where is the line in jack for my Gateway MC7321u Notebook? Is it one of the headphone jacks?
    Some computers have a special jack labeled line in. If your computer does not have a line in jack, you can use the microphone jack. You can then adjust the volume of the device in control panel under sound options. The headphone jack is only for output. I have seen some computers where you plug in a cable to the microphone jack and you will be asked what kind of device it is.
    Jan 17, 2011 | Gateway MC7321u Notebook
    Where can I plug the microphone in?
    Plug your microphone's pin into the red (or pink) jack out of the three jack sockets (blue, green, and red) that you see on the rear of your computer CPU. The newer computers may have these three jacks on the front of the CPU.
    Dec 04, 2010 | Philips SBCMD150 Consumer Microphone
    I don't know if my laptop has a mic, please help! :(
    Generally laptops from 1990-2005 had speakers that functioned as a microphone. Later laptops had a microphone port. Easy way to tell is look on the sides of your laptop, and by your headphone jack will be another port- that would be your microphone port. If you do not, go to accessories and pull up the sound recorder- if you see a sound response when you hit record and talk at your system, your laptop speakers are acting as a microphone.
    Oct 09, 2010 | Computers & Internet
    Where does the Microphone plug in to the Dell Vostro200
    Depending on the chassis-style of your Vostro 200 (Slim-line or Tower), you may have one or more options for installing a microphone.
    See below for instructions:
    A. Slim-Line Model
    There are two locations on this model (by default).
    Front: You have the power button, then 2 x USB ports, 1 x Headphone jack-out, and 1 x Microphone jack-in.
    Rear: There is a block of six audio connectors, looking only at the bottom 3 (red, green & blue).
    Red = Microphone jack-in Green = Speaker/Audio jack-out Blue = Audio jack-in
    B. Tower Model
    There is one location on this model (by default):
    Aug 15, 2010 | Dell Vostro 200 PC Desktop
    Microphone
    No, but it does have an input jack for an external mic.
    Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
    Thank You.
    Nov 17, 2008 | Dell Inspiron 1501 Notebook
    No response to my microphone
    1st try to check if the driver of your sound card is properly  installed in your operating system, if youre using windows it will be on the device manager 2nd if it is installed or its not showing then 90% would be a hardware problem on your sound card or the jack itself
    Sep 18, 2008 | ASUS A7V400-MX Motherboard
    Jack for the external microphone
    There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
    Sep 14, 2005 | NEC MobilePro 900 Handheld
    Tascam DP01 All-In-One Recording Package Microphone Logo
    42 people viewed this question
    Top Tascam Audio Players & Recorders Experts
    Sam Palermo
    Sam Palermo
    Michial Gueffroy
    John
    John
    Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
