Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell carpet shampooer
My bissell proheat clearview wont put out any water either on the floor or the hoses wont work either help water will come out of the hose for the furniture cleaner but not for the carpet. Have cleaned the machine and put it back togather. The machine is set for carpet cleaning
    Genius:
  • 3,422 Answers
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jul 20, 2008
    Guru:
  • 859 Answers
You did the hard work already, no sense in repeating that again.
What exactly is not working in floor mode? Beater Brush, Sprayer, suction recovery, or everything in this mode?
Worldvet
    Sergeant:
    Champion:
  • 347 Answers
Hello pfaul46,
Did you already check the manual?
http://www.bissell.com/images/UserGuides/7901_608.pdf
look on the top of the page 17, under troubleshoot
*reduced spray or no spray*
  • 19,396 Answers
Check that the ducts are not obstructed blow using an air compressor into the ducts, putting the compressor on water tank side, this should fix the problem.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
- Remove the tool from the end of the hose and see if the hose will spray. If there is spray with the tool removed, the tool is clogged. Clean out the spray tip of the tool with a safety pin or paper clip.
- Stretch the hose out and give it a few light tugs to release any kinks in the internal water supply hose.
If there is still no spray through the hose, please take your machine to a local BISSELL Authorized Service Center. To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com under the Customer Center tab near the top of the homepage. Enter your zip code in the Service Center box on the right of the page to perform your search.
Thanks
Good luck
Don't forget to rate the solution
My Bissell Proheat Clearview is not spraying water nor taking
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrthrw
Apr 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
How do I hook up my Bissel Proheat to clean my sofa?
There is a little switch on the side of the machine base that reads "floor cleaning" and "toos or preheat". Switch that to the tools setting and a little flap under the "clearview" shield will lift. Just take the hose off of the little rack and attach one of the cleaning heads. Check that the flap isn't blocked by lint or something. If this doesn't work you may have some other problem.
Sep 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
Can't reassemble top of carpet cleaner
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Took it apart and took the hose off the suction at the bottom and ......
heatman101
jhkf
Jul 06, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
First check that the top cover on the back side hasn't come loose. Sometimes the plastic around the screws break away and the top starts to separate, raising the tank, and no spray. Make sure that the gaket is on the valve at the bottom of the tank and not sitting loose in the hole. Check the pump belt. The pump may be bad.
Jun 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
My bissell powersteamer clearview will not **** up water
Check the heater inside of the handle, it may be clogged and not allowing water to flow. The hose doesn't use the heater and that would be why it flows out the hose.
Apr 13, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
762 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
