2004 55" Mitsubishi model #WS-55513 blinking green light
I have the same problem about the green blinking light as you had. Can you give the the solution to your problems and how much were the parts for the capacitors. I would appreciate if you could give me instructions on how to fix the problem. I am not good with electronics, so I was wondering how long it would take to fix it. Also how much did the parts cost.
Thanks
  • 3 Answers
Hey give me a call @1-714-401-3557 My name is Scott I too am an amateur but after a couple days and alot of investigating i found the problem....Its probably better explained over the phone....Thx Scott
Posted on Jul 19, 2008
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
The green light on my tv are blinking and the tv wont turn on
Get a blinking light repair kit from www.TvRepairKits.com - this model has some capacitors on the DM board that need to be replaced.
Apr 11, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Green light continues to blink. TV does not power up for Mitsubihi model WS 55513 TV
Howdy,
Try these ;
1. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001.
2. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V).
The board is on the left hand side of TV from the back. It is standing up, in a silver box.
Good Luck, BIG IRISH.
Jan 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Won't turn on WS 55513
Check the pico fuses on the back of the circuit. see if one has blown that seems to be another symptom on the WS models. They are little tiny ceramic fuses soldered to the runners themselves. hope this helps.
Jan 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
