Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Original Loaded My L7580 prints well and received faxes but when I try to fax out the paper goes through the top feeder just fine but when its done it doesnt recognize anything going through and cancels the fax. The screen says "original loaded" instead of showing the ink capacities and if i try to put a paper on the glass to either scan or fax it recognizes something being in the feeder and wont read the glass.
  • 3 Answers
I just came across this very same problem today on my L7580 and I found that there is a spring loaded bar that flips down and makes a contact. When paper is inserted it lifts this bar up and tell the feeder that there is a document. If this is stuck in the upright position then you will always have the "original loaded" message and have your issue. Mine had popped out of its alignment holes and I had to snap it in and the whole thing worked like a charm!!! I hope this helps everyone else with this issue!!!
Jason Gray
Posted on May 13, 2010
CLX-3185FW I would like to know how to send a fax overseas. Where do I put the paper to be send? Thanks
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
Sep 14, 2011 | RIM Computers & Internet
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
My HP 6100 series all in one wants to align cartridge
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
  • Faxes printing too small
  • Faxes printing on more than one page
  • A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu. The two main purposes of the Auto Reduction feature
  • Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
  • Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax in receiving faxes but not printing them.
noavatar.png Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
Apr 16, 2009 | Canon FAX-JX200
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Why is my printer saying original loaded?
Is there a piece of paper in the top (copier/fax) feed, or under the top against the glass? Original Loaded means there's some document in place, ready to be copied or faxed. If you remove that, the message should go away. If there isn't one, check inside the feed on top, and see if there's anything stuck in there that could be blocking the sensor.
Aug 28, 2007 | HP OfficeJet 7110 All-In-One Thermal...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
