Hi scottjette
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
Try uninstalling itunes and downloading the new itunes 10 i had the same issue and this helped me...
http://www.apple.com/au/itunes/download/
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
