Question about Panasonic Home Theater System System
Sa-pt750 Hello, I am trying to use the wireless speakers but the wireless device isn't working. The light stays red. Is there a switch or something in the menu that i have to turn on?
  • 6 more comments
  • Jodi3610 Oct 18, 2008
    I have the same problem. The wireless speakers aren't working the indicator stays red.
  • Anonymous Nov 09, 2008
    i dont know how to hook up wireless system
  • thorsp Nov 23, 2008
    Same problem
  • NewMom18 Dec 16, 2008
    Me too
  • amh626 Jan 09, 2009
    me too
  • sdbones Jan 12, 2009
    I have the same problem with the wireless device. Anyone able to help here?
  • lord_fomest Mar 29, 2009
    I have the exact same problem. the manual dosn't say "HOW" to pair them. Please explain in detail how we can "PAIR" them.
  • amh626 May 11, 2010
    i dont have a users manual and i dont know how to do a pairing process
  • 9 Answers
Is your main set is on while the transmitter card in inserted on main set?
If so, try do "pairing process" to pair up main set and wireless unit.
Pairing process can found in Operating Instruction manual which come along with the main set.
Posted on Jan 06, 2009
  • logistics233 May 28, 2011
    I have a Panasonic SC-PT850 and had the same problem. My manual does NOT mention pairing process. Here is how on the PT850 for those who are also find half finished "solutions" not helpful:
    1. Press skip forward button (>>) on main unit and #3 on remote at the same time. P will show up on display.
    2. Press the reset cavity on the back of speaker receiver with pointed tip of pen or whatever.
    That's all. It only took me 3 days of reading solutions like "read manual", or "check to see if unit is plugged in", or other silliness before I found someone with a complete solution explanation. If your model is different than SC-PT850, you will have to experiment with the different button combination, like I had to.
  • groovinit18 Aug 23, 2011
    OK, I tried that solution, got the P to show up, hit the reset on the wireless device...STILL NOTHING! I'm really frustrated w/ this **** thing. I'm not some dummy who wasn't trying surround. I tried that, tried DVDs w/ surround on w/ SRD. Sound, Movie Dolby..everything! Someone please help!
Cannot get the tv audio working. Radio iPod all work fine Panasonic surround sound sa-pt750
Hi. Make sure you get audio from tv from the right place. Ie audio out not audio in.
Nov 05, 2016 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
What needs to be done to repair my system?
It will be best to contact the authorized service center for Panasonic in this case. http://electronicshelponline.blogspot.com/
Apr 17, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
PT750 5 disc player is frozen reset to default?
There not like a computer, Or after market car deck. There is no reset on them.
Sep 04, 2014 | Panasonic Sa-pt750 5.1 Channel Home...
Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
May 30, 2009 | Logitech Z-5450 Computer Speakers
SA-PT750 rear wireless speakers don't work
Just solved this one thanks to another posting on this site.
Turn all components off.
Check to make sure your wireless card is snugly plugged into the back of the home theatre unit. (Of course you already have. Check again, though, while everything is off.)
Turn wireless unit on first.
Turn on home theatre unit.
The W1 light should be on and blinking red at you (darnit!)
Here's the magic.
Hit the >>/>> button on the front of the home theatre unit WHILE you hit the number 3 on your Panasonic remote.
The screen changes to a P
Then, the wireless unit light should change from red to green (HOORRAAYYYYY!)
If you have multiple wireless units, at this point, you should also hit the Set/ID button on the back of the wireless unit (it is the kind of button that requires something to poke into it to set it).
Then simply hit the >>/>> and 3 at the same time again.
All's good.
And by the way, shame on Panasonic. not only do they not seem to carry these manuals anymore (how hard would it be to have a PDF file and a link on a web page?) but the support info they did have did not contain these steps. Thanks to the FixYa member willray411 for posting this first!
Mar 29, 2009 | Panasonic Audio Players & Recorders
I have a panasonic SA-PT750 and when i turn it on all it says is F61 before this i was playing music on my ipod using it and started to make a wierd buzzing noise. Please help me!!
Hello,I have a sa-pt1050.I says in my manuel if this is flashing to check speaker cable connections,if this does not fix it consult your dealer
Jan 19, 2009 | Audio Players & Recorders
Sc-pt750
As far as I know there isn't any composite IN ports on the back of the SC-pt750 so that would mean you would have to directly hook it up to the TV. I have an SA-pt750, which has an S/PDIF port on the receiver so I would run a cable from the TV to the receiver, from there if the SC-pt750 is set to AUX then it should output the sound from the TV to the speakers. Hope that helps, if you don't have that S/PDIF port I think you might be out of luck!!
Nov 12, 2007 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
690 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
