Back to:
Tags:
Monitors
Generic problem for all Monitors
Dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic (by 2 users)
posted by lisad03 on Jul 19, 2008
I have a viewsonic lcd 19 in monitor that just went out of warranty and died 4 days ago.
the green light does not come on, it is dead, is it the power supply? we have tried plugging into different power supplies and nothing, can it be replaced or is it worth it?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by fhaddock, posted on Aug 09, 2008
My 19" viewsonic monitor has died as well.  Same symptoms as above.  Press the power 'on' button and nothing (absolutely nothing) happens.  Is it worth trying to get fixed or better to buy a new monitor (not viewsonic).
Solution #1
posted on Jul 21, 2008
Not Rated (0)
jackboy
Rank:Wiz Wiz
Rating: 77%, 3708 votes
If the power supply is not wqrking then it is the invertor unit that has dies.
Replace the monitor is the best advice- If it that recent out of warranty may be worth contacting 'viewsonic to see if they will discount you one.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dead monitor,,,,,,,,,,,,,,,,,,,lcd viewsonic:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Proview PL926WBi (Black) 19" LCD Monitor
the brightness window keeps coming up on the screen
Monitors
Screen flickers and flashes. Then settles down for a few...
E-Machines 19" Widescreen Flat-Panel...
I am trying to hook up a emachine monitor with my HP...
Acer AL1714CB (Black) 17" LCD Monitor
powers on,acer logo,black screen,power led stays green...
Dell UltraScan P990 19 in.CRT Conventional...
in my previous monitor before the dell i could plug in the...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
