Question about Blenders
Moulinex model 302
This is an old blender/grinder - it is awesome as far as blending quickly ,crushing ice shakes etc - i cant say enough about it - and would feel very lost without it - i tried to replace with a magic bullet but there is no comparison
i tried to replace with a cuisenart nope not as good as this little moulinex
my problem is this the little plastic part that sits onn the gear (it is about 1 inch high and 3/8in in diameter) has broken in half - i tried to super glue but that is a short term fix - how can i find this part?
  • Sarah Cassford
    Sarah Cassford Jul 19, 2008
    here are some pics for visuals
  • 3 Answers
Dear Sir,
Hello Nice to see you. I am from AHK TRADERS (pvt,) LTD. Our company will solve your problam. We have your required part for molines.
So contact with us by e mai. Hope we develop our business relation.
Waiting for your kind reply.
Best Regard.
M Mahmood M Aamir
MSN:: ahktrading@hotmail.com.
E mail::: ahktraders@gmail.com
Posted on Jul 24, 2008
Dear Sir,
Best Regard.
M Mahmood M Aamir
What are the best ways to use a Ninja blender?
It can perform almost all task of your kitchen, can make nice smoothies, prepare chunky ingredients and much more. It can crush ice fast. Would be a great choice for kitchen use, quickly prepare everything you want. It is also affordable and has stylish design.
Check out GroomNStyle.com for more information.
Jul 28, 2015 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Need grinder application
You probably can but it helps to know the model and what country you are in.
Jun 16, 2015 | Moulinex Blenders
When I make a frappacino I get lots of foam instead a slushie drink
You're blending at a high speed and air is getting introduced. Try a slow blend speed. This should solve your issue.
Jul 24, 2011 | Vitamix 5000 Work Top Blender
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
255 people viewed this question
Top Blenders Experts
eyecam
Mike
Are you a Blender Expert? Answer questions, earn points and help others
