Question about GE 46GW947 46" Rear Projection Television
Blue ghost on left side of screen only when on hi def channels
I have a ghost image of blue but only on the left side of the screen.  It only appears when viewing the hi def channels.  I tried the convergene adjustments they work but do not correct the left side issue.  The other digital channels seem fine...other inputs seem fine too.  I replaced component cables, and switched hi def cable box too.  Cable service wasn't familiar with problem.  Like the unit otherwise...just don't want to spend a lot for something i don't need to replace.  Suggestions?
    Scholar:
  • 167 Answers
Hello its sound like you need to replace the (IC chip) for your blue (CTR gun) .!!! its going bad.!!!hope this help's you ."good luck"
Posted on Aug 20, 2008
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
I have a comcast Motorola HD capable cable box with DVI output - going through a converter cable into an HDMI input. When I change from a hi def channel to a std def channed, the screen gets split, and...
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
Jan 04, 2010 | Panasonic TH-42PX60U Television
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony LCD cutting off image when hi-def cable hooked up.
This will happen invariably. Depends on the nature of the signal that is being received. Some will fill entire screen, others will not.
Just go with the flow - tv is operating normally.
Aug 23, 2017 | Sony WEGA KD-34XBR970 34" TV
Blue ghost
I have blue ghosts/shadowing at the top of the screen.
Sep 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Ghostly image with more Blue in Picgture
Yes you need to replace both STK392-040 convergence ICs. You can get new replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself in about an hour. They alos have free online instant messageing available to all there customers. heres the link.
http://servicemanuals.vstore.ca/
May 26, 2008 | Samsung PCL6215R 62" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
53 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
