Question about Samsung Televison & Video
Red Color Shaking
When I first turn the TV on the Red is color is clearly to the left of Green and Blue and shakes. After it warms up it comes in sync with the other two colors and the image is fine.
It is only a matter of time until it continues shaking and I loose the picture.
Is there anything I can do or do I need to call for a repair man? Is it worth fixing?
  • 3130 Answers
SOURCE: problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Posted on Jun 05, 2007
  • 934 Answers
SOURCE: shaking screen
Check the 9v regulator Ic2p01 on the signal board for correct regulation 8.9 to 9.1 volts. If voltage at the output is under 8.9v, replace the regulator Ic. Always replace C2p05 100 Ufd 16 V on this set and that should take care of the shakes but you may want the tech to go ahead and ESR some of the other troublesome caps throughout the Tv. He'll know what you mean. Many of the 100mf caps replace automatically. Several others will have a questionable ESR and should be replaced. Caps are inexpensive, but probing with an ESR meter is somewhat labor intensive so you miht discuss with the tech just how far you want him to go testing for bad caps.
A Mits is a great Tv and this repair is clearly worth it..
Posted on Dec 19, 2007
  • 5138 Answers
SOURCE: Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
Posted on May 31, 2008
  • 125 Answers
SOURCE: No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Posted on Aug 13, 2008
  • 74 Answers
SOURCE: Older RCA Projection screen, Blue picture!
take the front speaker cover off, then remove the four screws on the cover behind it. you will see a 2"x2" black thing with 6 controls on it 3 on top three on bottom, your looking for "screen". they should also be marked r g and b, try turning the blue down (counterclockwise). it may help a little and prolong the life of your tv
Posted on Sep 10, 2008
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Philips 23PF9966/37 color problem!
Most likely you can adjust it in the Service Alignment Mode (SAM).
Press 062596 followed by the STATUS button (upper left). Navigate to "White Tone", press the right key to enter and select "Normal" mode. Set the colors:
Red = 135, Green = 128, Blue = 133.
The "Cool" and "Warm" menus are deltas from the "Normal" settings:
COOL: R -3, G -1, B 5
WARM: R 2, G -3, B -13
Press the "MENU" button to return to the main menu, then the "Power" button to turn the TV off.
Jun 15, 2009 | Philips 26PF9966 26 in. LCD Television
Try to adjust it in the Service Alignment Mode (SAM).
Jan 04, 2009 | Philips 26PF9966 26 in. LCD Television
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Televison & Video Logo
217 people viewed this question
Jerry Greenberg
Jerry Greenberg
