Question about Passport 8500 Radar Detector
Laser The Laser alarm goes off all the time. I tried to hold all 3 buttons down then turning it on, the problem is still there. HELP Mike
  • audit0r Sep 22, 2008
    mine does this too and when i honk the horn...but it doesnt do this in other cars
    Sergeant:
  • 347 Answers
Have you tried it in another vehicle? are you near an airport? has it done it from day one or recently started doing this?
Posted on Jul 26, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
Drum, alarm, and data lights on--won't prnt
This unit might need resetting!
Here's how..
There's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Aug 01, 2010 | Brother HL 1440 Laser Printer
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
MX3200 Cordless Keyboard alarm clock
Hold down the FN button (next to the right CTRL button) and press the F11 button.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
Aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Feb 11, 2008 | Watches
Passport 8500 Radar Detector Logo
180 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
