Question about LG DH404E Dehumidifier
Fan does not go on
The fan does not go on
I had the same problem with my unit. I checked the fan motor with a ohm meter and found that both low and hi speed windings were open. New fan motors can be found on ebay, but changing them involves some work.
Posted on Jul 21, 2008
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Fan barely turns
If the fan is barely turning, it could be the fan is bad. This fan blows air across a 2 coils.
May 29, 2014 | Haier HD456 Dehumidifier
The unit turns on compressor and the fan after awhile the fan turns off and compressor still on.
Sounds like it is a bad fan or bearings. Try shutting off the unit as soon as the fan shuts off and see if the fan turns freely. If not, the fan bearings need lubrication or replacement. If they are not serviceable, you will need to replace the entire fan.
May 19, 2014 | Frigidaire FDF70S Dehumidifier
The cooling fan and will not shut off.
theres a fan/compressor relay inside the case one side operates the fan and the other the compressor,if the fan side contacts weld themselves the relay cannot cycle and the fan will not shut off,remove the wire from the relay to the fan and see if this kills the fan,but dont leave it this way as the compressor needs the fan for air circulation while operating
Feb 26, 2011 | Haier 45-Pint Dehumidifier
Very loud vibration when the fan runs.
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
May 15, 2010 | Goldstar DH504EL Dehumidifier
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
Motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Aug 19, 2009 | Kenmore Dehumidifiers
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
Jul 03, 2009 | LG Goldstar LD65EL Dehumidifier
Fan runs all the time
I HAVE HAD A COUPLE OF UNITS THAT HAVE KEPT THE FAN RUNNING ALL THE TIME. I REPLACED THE CONTROL AND THAT TOOK CARE OF THE PROBLEM.
Mar 09, 2008 | Whirlpool AD70USS Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
LG DH404E Dehumidifier Logo
191 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
