Question about HP Compaq d530 SFF PC Desktop
Restore Disk I got this base unit from the Hilton group as it was being sold off as no longer needed, but the problem is that it has all the network and admin stuff on. I need a restore disk in order to save it back to its original setting as Hilton dont have the disk available in order for me to do this. Can you tell me where I can get a restore disk for this model
    Problem Solver:
  • 17 Answers
Www.hp.com go to the drivers and support pages, search for your model. disks should cost 15-30 dollars, depending on the model.
Posted on Aug 28, 2008
How can I obtain restore disks for a Zt 2176La desktop computer? Hard drive has failed.
I had the same problem didn't have a restore disk but you should have one that came with the system I restore mind with out the disk --( just type this in) how to restore pc are laptop to factory setting page will open follow instruction and once done you will be good to go let me no how you came out good luck
Sep 23, 2014 | ZT Group Computers & Internet
Lexmark t644 how reset nvram
Entering Configuration Menu
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
Then Go to Factory Defaults
This setting enables a user to restore all the printer settings to the original factory settings. Selections are Restore Base and Restore Network. Network does not appear unless you have a network printer. The following settings are not changed:
• Display language
• Settings in the NETWORK/PORTS MENU group.
This resets the non-critical areas of the user NVRAM
Jun 30, 2011 | Lexmark Office Equipment & Supplies
I have samsung J-150, i have need unlocking code of paris hilton's diamond quest.
If you need unlocking code means you can get the unlocking code here theunlockspot.com to your mobile Samsung j150...You need to specify the network provider...check whether there is unlock code is available for your network provider or else contact the service provider...
Jun 20, 2011 | GE 29255GE2 Corded Phone
Espressione CA4865 Supremma Super Automatic machine will not transfer water into the system, but rather leaks out the bottom! What can be done to fix this?
I have same unit. Produced by Solac in Spain. No longer sold in U.S. Solac won't help.
I had leak out bottom of machine. Removed brew group and tightened phillips head towards front which was loose. This stopped the leak on mine. Hope it works for you.
Mar 27, 2011 | Espressione CA4865 Supremma Super...
Trying to purchase a replacement parent handset for SCD520?
You can't. I just called Philips and apparently if the parent monitor stops working for whatever reason after the warranty has expired, there is no way to send them off to be repaired and no way to purchase a separate parent model. You are STUCK with buying the whole package again. I have a perfectly good base, but the parent model got into the hands of the child and no longer works. The parent units have to be sold with the base. These parent units are so vulnerable; can't believe there is no way to purchase a replacement. No happy with Philips.
Feb 05, 2011 | Philips Avent Scd520 Dect Baby Monitor
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
http://windowsxp.mvps.org/srpolicy.htm
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface
http://support.microsoft.com/default.asp…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
-or-
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to http://www.pcreview.co.uk/forums/thread-…
Perhaps one of these links will give you the correct solution
http://forums.techguy.org/windows-nt-200…
http://www.winhelponline.com/blog/restor…
http://www.computing.net/answers/windows…
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
Restore
Within the interface there are 2 options. one for backup and one for restore. using the restore, you can select the files that you need and complete the restore
Aug 08, 2008 | Veritas Backup Exec 10 for Windows Servers...
Ethernet and usb not working
use your recovery disk tHAT CAME WITH YOUR COMPUTER TO RESTORE THOSE DRIVERS BUT BACKUP ALL IMPORTANT DOCUMENTS & PRINTER DRIVERS fIRST.
Jan 17, 2008 | Itronix GoBook IX250 Notebook
HP Compaq d530 SFF PC Desktop Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
