Question about Mag Innovision InnoVision XJ 717 Monitor
Television Sony kp53xbr300 projection television stand by light blinks 5 times every three seconds The set has sound but no video what is the problem and solution
  • 25 Answers
Replace the horizontal transistor near the EHT.
Posted on Aug 30, 2008
Projection TV Sony, first power on only hear the sound for couple second then turn off. Stand by light keep flashing 5 times. What's wrong and how to fix?
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
Jul 18, 2014 | Sony KP-51HW40 51" Rear Projection...
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
No picture, no sound. Stand bye 4 red light blinks
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KP-53S70 53" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony KP-57HW40
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Feb 19, 2008 | Sony KP-57HW40 57" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KDF55WF655
TURN TIMER OFF OR, The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jan 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Front panel timer/stand by blinking light
did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Sep 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Mag Innovision InnoVision XJ 717 Monitor Logo
32 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
