Question about GE Refrigerators
GE fridge mn Pds22scrblss
My freezer is warm there is a hot spot on the front between the bottom freezer and the fridge above that is hot enough that I cant keep my hand on it for more than a few seconds
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
Posted on Feb 07, 2008
  • 109 Answers
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Posted on Mar 31, 2008
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
  • 544 Answers
SOURCE: GE Model # GSS20IEPA WW Fridge warm...freezer is fine
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
Posted on Mar 28, 2009
That is usually a heating element that is used to prevent condensation from developing in that area. It should cycle on and off and be slightly warm, but not get real hot. Check around your controls and see if there is a switch for something like Energy control or something like that, the exact term is escaping my memory, and you might be able to turn it off. Hope this helps!
Jul 12, 2015 | Admiral Refrigerators
Ge profile fridge model PSC 25MSW/PCF 25 MG W PSH25MGW freezer works fone but fridge too warm.
Check to see if you can see any ice building up in the damper between the frig and freezer.
Oct 23, 2014 | Refrigerators
Fridge does not seem cold enough. It is maybe 12 years old. Do I need a new fridge
The heat between the doors is normal but not really hot. if sides and between the doors is real hot then you have an air flow problem. Vacuum coils under it and coils by condenser fan. Check your Condenser fan by compressor.
Jul 28, 2013 | Refrigerators
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
147 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
