Question about Dishwashers
Whirlpool Quiet Partner Leaves cloudy stains
Our fairly new, 3 years max, dishwasher started to leave white-cloudy spots in all our dishes (plastic, glass, pots, etc.)  All the cycles seem to run correctly.  We use gel dishwasher detergent.  It's very hard to get hot water in our sink, but I believe it's do to our faucet.  I believe we do get hot water in our dishwasher, or maybe it gets hot inside of the dishwasher.  I'm not sure.
Please help, Rosa
SOURCE: detergent compartment doesn't empty out during washing cycle
check your fill valve.
Posted on Nov 23, 2008
ldsaunders
  • 31 Answers
SOURCE: my dishwasher leaves a cloudy residue on my dishes
The cloudy residue that is left on your dishes is soap that has not completly broken down.
There are a few solutions to the problem. First off, you want to ensure that you are using the "high temp wash" option. This will boost your water temp during the wash cycle to ensure that all the soap breaks down.
The second thing that you want to do to give your dishwasher a boost, is run the hot water in the sink and make sure it's pipping hot before you start your dishwasher. What this will do is ensure that the water that goes in for the "pre wash" portion of the wash is hot and will improve the wash quality.
Posted on Mar 01, 2009
  • 677 Answers
SOURCE: dishwasher Soap scum left on dishes
the problem is hard water. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Posted on May 13, 2009
localwonder
  • 6784 Answers
SOURCE: whirlpool dishwasher QUIET PARTNER II doesn't
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Posted on Aug 16, 2009
  • 10 Answers
SOURCE: our new quiet partner III by Whirlpool is not
I have a Maytag model MDB9100 about 9 years old that's not worked well recently. Here what worked for me.
If the obvious solutions listed in your owners manual don't solve your problem the filters may indeed be the problem. Start by removing the lower spray arm. There is no need to remove the arm from what I'll call the "arm base/cover assembly"; keep it clipped on. At the center of the arm is a knurled screw. It looks like a thin disk with several bumps on it, about 2 inches in diameter. It will unscrew (lefty-loosy) and allow removal of the arm assembly. At quick glance it appears to be a molded part of the arm but that's a clever disguise. Making this part a different color would be too helpful. What else would the Maytag repairman do it they made it easy for the do-it yourselfer?
Anyway, after removing the spray arm take note (or photos) of the visible parts, i.e, spray nozzle, 2 split plastic spacers. Be sure you'll be able to return these to their proper position later.
Remove the six torx (star-shaped) screws and lift the impeller cover off. Again note/photograph the position of remaining parts, i.e. filter, impeller. You will likely find the filter clogged with debris. It can be pulled out. On my model it is retained in a groove and take a bit of force to remove. I used water pressure (sink sprayer) and a toothbrush to clean my filter.
Remove any debris from the sump/ drain area. Reassembly is reverse of installation. Be sure to flush out the arm assembly to unblock all holes before re-installing it.
I hope this helps.
Posted on Feb 04, 2010
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Dishwasher dishes cloudy and makes loud buzzing soundf
I am not sure about the buzzing but cloudy dishes is caused by
hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 03, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a new Ge profile modesl pdw7880 dishwasher. It does not clean the dishes. The glasses have a milky white film and spots. The black arm on the bottom has a white coated build up. Also there is a...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 14, 2011 | GE 24 in. Profile PDW7800 Built-in...
We get a white film on the dishes, glasses and plastic glasses in the upper tray of this new dishwasher. What is the cause and what is the solution?
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Feb 11, 2011 | Frigidaire FGHD2433K 24 in Builtin...
I have had my dishwasher for over 5 years and it worked wonderfully however in the last 2 months it is leaving a film on my glasses and pots and pans. it also doesn't seem to be rinsing very well, i have a...
Feb 08, 2011 | Maytag Dishwasher
We purchased this unit in 6/10. It leaves a film on my plastics and does not get my dishes clean (glasses, silverware). I use Cascade complete and jet dry. I don't know what is wrong. Please help.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Feb 07, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
After running my GE Nautilis there seems to be soap scum on all the dishes. I can't seem to get them clean. I have even tried using jet dry and yet the glasses still come out very cloudy. How can I fix...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Jan 14, 2011 | GE Nautilus 24" Built-in Dishwasher
Glasses int he top rack of my kitchenaid dishwasher don;t get clean. they finish the run spotted and covered in what looks like baked on dirty dishwater. dishes in the lower rack look ok, but the...
Jan 11, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Right after 1 year, now there is a white film on all the glasses and bad spots, that rubs off if you wipe it fresh out of the dishwasher. Yes, we are using rinse aid.
Dec 04, 2010 | Whirlpool 24" Black BuiltIn Dishwasher...
Some of our dishes in the top and bottom rack are showing a white film, especially on plasticware and the outside of pots, pans, ceramic or regular glasses. Also some glasses on top rack , but not all,...
Nov 19, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwashers Logo
157 people viewed this question
Top Dishwashers Experts
