Question about Ruud UAMB Air Conditioner
Replacing fan motor in a RUUD air conditioner
Husband bought new motor but not sure if the wiring is the same as old motor. Need help in wiring new motor.
Friend wired the motor to the unit.
Posted on Jul 21, 2008
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
I have a Rudd 240V air cond and changed out the condensor fan motor that had 3 wires brn, blk and org. the new one has 5 wires,brn,blk,org,blu,yel. which wires do I connect to relay and single capacitor.
If you will look on the side of the new motor is should show you. But the black and brown will go in the same place as your old one. Generally, the yellow will replace the orange.
Black is hi speed and will be connected to one side of the "relay"
Brown is capacitor by itself
Yellow is common on the other side of the capacitor and will link back to the "relay"
Again, be sure to check on the side of the motor. Yellow should be noted as "common"
Be sure to tape the ends of the wires not being used before you power it up.
May 01, 2011 | Ruud UBHC Air Conditioner
How do I troubleshoot a ruud a/c fan motor
You can disconnect the compressor from the contactor and wire the motor up to the 220 to see if
fan will run. If fan turns hard by hand, replace motor otherwise you may just have to replace the capacitor.
Jun 27, 2010 | Ruud UAKA037 Air Conditioner
Air handler motor stopped working
Check the capacitor before you replace the motor. It's a common problem that's easily fixed. Make sure the fan rotates freely.
May 23, 2010 | Ruud UBHC Air Conditioner
Replaced fan motor have to use another capacitor not sure about wiring went from 3 prong to 2 prong
on the sticker on the side of your new motor it will say the cap needed. it most likely will be a 5mf cap or a 7.5 mf cap. use the rated cap for the motor. Steve. arcticacservice.com
Jul 11, 2009 | Ruud UAKA037 Air Conditioner
Blower motor on my Ruud furnace won't turn on when the a/c is on also won't turn on manually
You need to buy a new fan motor. If you could have turned the fan with your hand all you would have needed would have been a capacitor. If your filter is always dirty or the a coil is dirty will shorten the life of a fan motor. Just for things to consider in the future. Now if the unit is about 10 years old just wore out. Get a new capacitor when you get new fan they are cheap well 5 bucks any way.
Jul 07, 2009 | Ruud UBHC Air Conditioner
Replacing the fan motor on RUUD model # UHBC-21J14SFC
remove control make sure make diagram where motor wires go on board. some models have 2 screws to pull out entire blower assemebly
Feb 18, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud UAMB Air Conditioner Logo
227 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
