Question about Passport 8500 Radar Detector
Passport 8500 escort
Can you tell me how you fixed the Laser going off all the time. I hope that there is an easy fix, Thanks , Mike
  • 304 Answers
If you are in an area where the police are not equiped with laser radar guns, most areas are to cheap to implement them, you can simply cover the laser sensor with black electrical tape and this will prevent it from going off every time you go anywhere near store with door opener sensors and a million other none cop sources of reflected laser light. Also if a cop hits you with a laser it is traveling at 186,000 miles a second and I don't think you will be able to hit the breaks before he gets the reading. the laser only goes off where he tags someone. Basically laser radar detectors are useless. This solution works 100%
Hope you find this information useful. Feel free to contact me with all you technical questions. Don't forget to rate me.....
George
Posted on Jul 19, 2008
  • George Kohler
    George Kohler Jul 21, 2008
    I'm glad you found my solution Helpful. In return I ask you
    to go to my profile and read and rate some of my other solutions. I put
    25 years of experience, 3 years of Deans list University Dual Degree's
    in Business Management/Computer Science, 2 Years of Tech School for
    Industrial 3 Phase Wiring, Founder of three major businesses and 1 hour of research into nearly every
    post barring the short and obvious. As my post helped save you, I ask
    you to help some others by weeding out some of the garbage that winds
    up slipping though here. Some of the posts even involve "experts"
    recommending owners powerful dangerous vehicles do a cobb job fix
    instead of repairing the advanced handling system specifically designed
    for the saftey of the vehicle.
    Please take a few minute and go to my profile and go through
    my
    unrated posts and rate them objectively and fairly and you can help
    some others the way I helped you. Check out some of the comments on my
    online chats. You will see I'm constant and Your case was not just a
    fluke.
    Thanks,
    George
  • George Kohler
    George Kohler Jul 23, 2008
    Could you please stop back an re rate this fixya. Some keeps messing with the posting hear. Thank for your time.
    George
  • 790 Answers
Hello!!
Hold all three buttons down and reset it.hope it fixes the problem!!
Regards
Smilemaker
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Service Required
use the scanner and computer test for easy diagnostic, go to the mechanic and fix it.
God bless you
Sep 30, 2013 | Passport 8500 X50 Radar Detector
Getting false laser readings, any adjustments?
This is fixable as described in other threads here. This is annoying and seems to be random, though it also does it sometimes when the wipers are turned on or I use the windshield sprayer. 2 minutes with a smal Philips screw driver and a Q-tip will fix it. I just did mine and it works great now.
Unscrew the three screws, pop the three components apart (it really is a no-brainer since they only fit back together ONE WAY, so don't be nervous. There is not anything that is going to fall apart or spring into a hundred pieces in there.
I used canned air to blow everything out and just used the Q-tip on the front window and the parts that looked like the detector window internally... I didn't bother swabbing all of the board.
IT WORKS! GREAT FIX!!!!! DO IT!! NO MORE FALSE LASER ALARM WHILE ACCELERATING and randomly.
Apr 27, 2010 | Passport 8500 Radar Detector
Passport Radar service required
The internal diagnostics have detected a problem with the detector. You should contact Escort Customer Service directly for assistance, below:
http://www.escortradar.com/customer-service.php
Sep 27, 2009 | Passport 8500 Radar Detector
I also have a 8500 passport that flashes laser and will go off
Does this happen in the city or does it happen when you are out in the middle of nowhere? I have seen laser detectors that are falsely triggered by various lighting devices that contain wavelengths of light similar to those used in police laser.
If this is annoying and you dont want to hear it, you can locate the receiver element that detects the laser signal and cover it up with a piece of black electrical tape. That should stop whatever is causing your problem unless there is something actually broken inside the unit.
Thanks,
r
Aug 21, 2009 | Passport 8500 Radar Detector
Put Escort passport 8500 X50 into calibration mode.
If you hold down the mute button (on front) and the two buttons on top...when you power up, it will reset.
Mar 20, 2009 | Passport 8500 X50 Radar Detector
Compare laser Kat600 with escort 8500x50
The Escort 8500 X50 has better performance in all respects. As far as I am aware, Kat RDs are no longer being manufactured.
Mar 19, 2009 | Passport 8500 Radar Detector
Escort passport 8500 error 13
This is an error message which indicates a specific internal component failure. Escort will have to fix your 8500.
Dec 30, 2008 | Passport 8500 Radar Detector
Laser problem with radar detector
This is caused from voltage fluctuation. Your car will draw down power from the radar detector and it goes off. Passport/escort need to come out with an inline voltage conditioner. Maybe soon.
Aug 27, 2008 | Passport 8500 Radar Detector
Laser
have you tried it in another vehicle? are you near an airport? has it done it from day one or recently started doing this?
Jul 19, 2008 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
220 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
