Question about GE WSXH208A Front Load Washer
Ge gcrh410h0ww front load washer
The problem that i am having is when i press the start button it beeps and flashes the "control button". I have unplugged and plugged the machine. I have checked to make sure the door is secured. Nothing is working. What do you suggest
Coldcut
  • 1554 Answers
SOURCE: GE WHDVH626fWW Door Locked, but not
As most these washers use the same control board.
try some of the troubleshooting you see here :
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
The main relay (black one on the right of board ) may be at fault in your issue.
these boards have bad solder joints in most all cases.
If its still in warranty it time to call them.
If you open it please post pics.
Posted on Feb 03, 2008
  • 240 Answers
SOURCE: GE Front load washer - cannot unlock door
manual lock release is located inside front panel. remove lower kick panel and reach up on latch side and feel for plastic tab hanging from lock asm. pull down.
Posted on Apr 27, 2009
SOURCE: GE washer: door won't unlock
We had the same problem and there is a wiring harness right at the door and I guess over time closing the door or the vibration from the spin cycle worked it loose. It would click and click like it was trying to lock but then the cycle would not start and it would just humm like it was trying to start the water. Make sure before you start to unplug the washer. The harness plug is on the side of the drum right at the door. If you take the bottom panel off and take the bottom two screws out and pull the panel out as much as you can you can see it there on the side. Just plug it back in and you are good to go.
Posted on Jul 09, 2009
  • 1531 Answers
SOURCE: GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Posted on Feb 06, 2010
SOURCE: ge front load wcvh6600.
take the bottom panel off three screws and put your hand up where the door is located feeling blindly for a plastic latch....pull the latch to manually unlock door..... then with the door open unplug washer and wait 10 minutes...even if you have done this before this is different b/c the door will be open....still open plug back up and turn on..if the display comes on its the door lock...about $94.00 if no display its the panel board and that'a about $ 200.00...hope this helps too
Posted on May 29, 2010
What is the sequence to get code to find out washer malfunction?
Press both the start and pause buttons together and count the beeps. Then the light above the start button will flash so count those. Example is 5 beeps and 9 flashes means error code E 5-9
Jun 29, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
Press the start/pause button on washer and it beeps at me. Won't let me start my load.
I would check that the front is secure. My old front end loader would kinda do the same thing. If I didnt have the door exactly shut it wouldn't start. Start there hope it helps
Dec 15, 2010 | GE Energy Star WCVH6260F Front Load Washer
Feb 06, 2010 | GE WSXH208A Front Load Washer
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
Kenmore elite front load washer
Make sure they didnt lock the control panel if it just beeps when u press buttons that might be it. there is a button u can press and hold for 3 seconds to lock and unlock the control hope that helps
Mar 13, 2007 | Kenmore 44072 Front Load Washer
GE WSXH208A Front Load Washer Logo
158 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
