Question about Dell PowerEdge 2600 Server
New HD in PowerEdge 2600
Im running low in space in the primary HD. I bouth a new 73GB SCSI HD.. I only have one HD I need yo add the new one.. Do I just put it in .. its hot swap?
I don´t use RAID.. Just need to add the new HD as a separate HD..
  • uurrozm Jul 20, 2008
    thanks for the respond.. I dont want to turn off the server.. so I just put it in with the server on?
  • uurrozm Jul 21, 2008
    thaks for the help
    Problem Solver:
  • 4 Answers
Hi, PE2600 supported hot plug HD. here the documantation
6 hot plug hard drives
optional 2 x 1 hot plug drives in media bay
584GB max hard drive capacity
Ultra 320 and Ultra 160 10K and 15K SCSI drives
Posted on Jul 29, 2008
  • 21 Answers
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Posted on Jul 19, 2008
  • Venkat CV Jul 21, 2008
    Yes. Just pop it in, and have the disk formatted when it gets identified.
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Dell Poweredge 2650 - How do I disable RAC
If this is a security concern then there is nothing to be concerned about so long as you do not plug a network cable into the RAC.
Otherwise, if it is an add-in card just remove it.
If you can't remove it there should be a way of accessing it when the server starts up. You should be able to go into the configuration and disable its functions.
I hope this helps.
Jul 05, 2009 | Dell PowerEdge 2600 Server
Regarding Adding Higher Configuaration HDD Into Exisisting Raid 5
In raid 5 yes you can, yet you won't use the ful hard drive, the system will take only 73GB because that's the smallest HD in your array.
Just, of course, follow the indications for your specific RAID hardware/software about how to add a new HD to it:
http://support.dell.com/support/edocs/software/svradmin/1.9/en/stormgmt/cntrls.html
Mar 20, 2009 | Dell PowerEdge 6600...
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Jan 12, 2009 | Dell PowerEdge 2600 Server
Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Dec 11, 2008 | Dell PowerEdge 2600 Server
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Nov 05, 2008 | Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Jan 06, 2008 | Dell PowerEdge 2600 Server
New HD
What controller do you have and are you doing JBOD?
Oct 30, 2007 | Dell PowerEdge 2600 Server
SCSI and IDE HDs, can they work together?
This next solution is viable in win 98, and I don?t see any reason why it shouldn?t work for you too. If you know of anything I?m missing you should consult someone else. The solution is slightly complex, so I hope I can explain it properly: 1. Create a startup disk so you can format and install windows. 2. Set the new HD as master and connect it to Primary IDE. 3. Disconnect the SCSI and remove it. 4. Restart the computer with the disk you created (with the new HD connected). 5. Go to the Bios settings in order to make sure that the computer does recognize the new HD as the primary drive in the first IDE. 6. Now, FDisk the new HD, set the partitions, restart and format it. Install the OS and make sure it is working properly. 7. Insert the SCSI and restart again. 8. At this stage the computer would reboot into the IDE and see the SCSI/ You may have to change something in the OS settings for that, but I don?t know where. Good luck.
Feb 22, 2006 | Adaptec SCSI 29160 POWERDOMAIN MAC KIT...
Dell PowerEdge 2600 Server Logo
238 people viewed this question
Alun Cox
