Question about Electrical Supplies
Gas to oil ratio
I have misplaced the instruction book for my weedeater and can not remember what the gas to oil ratio should be for my model. Are they all about the same? I have a Craftsman Incredi-Pull trimmer/edger, model #316791890, as best I can can read the label for it is faded.
    Champion:
  • 254 Answers
This mixture for this weedeater is 40:1 or 40 to 1
Hope this helps You
please rate me
Posted on Jul 24, 2008
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
How do you know whether to use 50:1 or 40:1 gas/oil ratio mix in a 2 cycle engine ?
should be written in the manual and on the lid if not i always run 40 to 1 better safe than sorry to much oil ratio can foul a plug running to light on oil can blow the motor
Nov 07, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
40 to 1 is most common. The safe thing to do is buy the oil and mix per the instructions on the oil. Not all oils mix the same. Use the oil recommendation on the bottle.
Sep 08, 2010 | Poulan Garden
What ratio gas to oil do I mix?
Use 3.2 oz of 2-cycle oil to one gallon of gasoline. If you use 3.3 up to 4 oz you would be okay nut it may smoke a little. Sorry to hear about your husband. Good luck...Lee
Jul 29, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Electrical Supplies Logo
343 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
